I have recently put a big turbo on my gtst and after having it running without an exhaust, (just to make sure it still runs) it wont start. I get a warning light of the dash coming up when i try to start it.
The car does not crank at all, when you go to crank it all you here is a click, sounds like its coming from the starter motor. Battery is fine, and also my windows dont go up or down now could this be the same problem?
I think the warning light might be exhaust gases or something.
Any ideas,
cheers
Edited by SL1D1N
https://www.sau.com.au/forums/topic/175263-car-wont-start/
Any ideas,
cheers
Had that happen to me recently and it was the battery (drained by the alarm coz i haven't started up the car in a while)
https://www.sau.com.au/forums/topic/175263-car-wont-start/#findComment-3212342
I have charged the battery since then and had it running also tryied to jump start, i know what its like when the battery is dead. Its not like that its a single click coming from the starter motor area. Also i think a exhaust fault lamp comes up as well just as the keys turned.
https://www.sau.com.au/forums/topic/175263-car-wont-start/#findComment-3212840
2 signs of a stuffed battery. Even if it was something like a seized motor, if you had a good battery your windows would be working?! Did you disconnect the battery when installing the turbo? didnt do something stupid and hook it up backwards by mistake?
https://www.sau.com.au/forums/topic/175263-car-wont-start/#findComment-3213030
Nahh disconnected the battery when did the turbo, will have a play with it and get back to you, im starting to think im the immobiliser.
thanks for the help
sorry didnt realise was still in mates user
https://www.sau.com.au/forums/topic/175263-car-wont-start/#findComment-3214868
jack power from someone elses car...
you may get that extra volt or two that you need if the other car gives it a rev...
if it doesn't crank then, think about sourcing a new starter motor, or get your alarm looked at...
https://www.sau.com.au/forums/topic/175263-car-wont-start/#findComment-3214883
OK i need help BAD
Battery is fully charged and have tried to jump start off other vehical, also tryied role start but wont start.
Both windows stopped working at the same time the car stopped starting.
Turn the key one turn radio and clock turn on and work fine.
Second turn all the usually lights come on and my safc turns on and still everything works fine.
Go to crank and you can here a single click from the starter motor area and the exhaust temp. warning lamp comes up. Could this lamp be the problem
Help
https://www.sau.com.au/forums/topic/175263-car-wont-start/#findComment-3222409
    • I ❤️ Matty I would like to thank Matty for going out his way in securing me a OEM NC detachable hard top for the NC Matty, your worth your weight in gold, and I cannot say how much I really appreciate your outstanding help I'll get it colour matched once I pick it up sometime in Dec-Jan 😁
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
