Can sombody tell me a good place in QLD to grab up a new/second hand R200longnose LSD? Think mine has shot itself, had a look under the car and i seen that the tailshaft centre bearing was dead so i replaced it. But im still getting a loud Clunk when taking off/changing gears/backing off. To me it sounds like it comming from the front of the diff where the tailshaft just go's in. Also have 2" of play back and forth on both wheels when i jacked the car up.
Cheers. Clint
Edited by Clintarous
https://www.sau.com.au/forums/topic/175281-r200-longnose-from-hr31-passage-gt/
Cheers. Clint
Or even a rebuild kit, seals and bearing etc. . .
Ok, took diff into a diff joint today and they said it was fine. Also said to check diff mounts and bushes and so forth. also said it could be in the gearbox and traveling down the tailshaft. I just replaced my centre bearing also, so i know its not that. wo0t. life of cars. great!
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
