  • Replies 47
What do they actually replace with these high flow units? And what kind of thrust bearings do they use? old, new, 360o? I have had mutiple garrett units fail in various applications and seem to see similar characteristics in all. However am yet to see it in my trust units...just wondering if there are any noted differences here.
LOL yes, but what components are used, what thrust washers.
I do know that two b/b units built by garrett only used smaller degree thrust washers, turbos failed soon after, apparently rebuilds do not automatically qualify for the 360o thrust washer...perhaps this is the problem.
So no one can confirm exactly what is used in each application? Or if its actually brand new?
Also in the failed applications are ppl running bovs?
The added surge increases load on smaller degree thrusts, (under 360o thrusts might already be a problem in themselves) and can easily be one of the contributing factors to these failures, not just in ball bearing units, but in all turbos.
Edited by 33gtst
You can always ring GCG if your worried.
For the 1000's of units they have no doubt sold, one or two failed. Doesnt mean much to me.
I had a GT30 fail in less than 5,000km's. But thats just how it goes.
ok so it doesnt mean much to you, but I was simply replying to what I believe might be one of the contributing factors as to why these units are failing...which is the original question, so I think it might matter to salad.
I'm certainly not worried, I have tried turbos from gcg, garrett, nissan and I will never install another garrett/or garrett supplied unit on any of my vehicles, but this thread wasnt about me.
I'm still yet to see valid evidence of how no BOV actually damages a turbo.
It just seems weird to me that all oem vehicles since the early 1990's come std with factory fitted bovs..I guess they like the wank factor and have no justification for them whatsoever. I'm sure they actually have put in substancial r + d into this prior to the added expense of fitment and supply on their vehicles. However sadly I cant confirm the exact reason, I can only speculate from what I have seen and tried with my cars and my garrett dramas.
Im not saying no bov causes premature turbo failure, on its own, but perhaps when consistancies are appearing in these failures that has to mean something.
Are the thrusts unable to cope with the added surge, that maybe the 360o thrusts cope better with? Are those running a bov still experiancing the same failure and symptoms?
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
