  • Replies 56
Posted Images
  • 3 weeks later...
Hey guys great idea... just a quick side note... one of the boys i work with did a wedding for a mate in his hotrod and when people threw confetti it stained the paint. so just something to think about or watch out for.
off topic but "risking" has some 2835's that are near new for sale. (gtr)
From my replies...so far I have one definite, and one maybe.^^.hopefully as the bride to be likes the candy red >_<
need at least 4 cars total....
Looks like I will be driving my own car to the wedding....
so would like someone with a R33 and/or R34 GTR to help out please
I know less than 2weeks is not much notice, but I have had this topic up for at least a month >_<
Thank you for your consideration, and hope someone can help me out :rofl:
A VERY BIG THANK YOU TO NICK (AKA GTS-T_Sedan) :)
He was the only one out of everyone that replied to me, that actually turned up!!!
Apart from one of my friends in his R32, and me driving my own GTR, Nick was able to save me from my fear of involving a commodore.
I have no idea what was with people trying to sell things in this topic? :)
Enough said... Just thought Nick needed a round of applause...
Thank you :)
J
lol yeh no problems man glad i could help out
Hope u had fun last night and congradulations
I had fun doing it though, and would do it again
Now all we need is pics :)
Congradulations again and hope u enjoyed married life :)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
