..and just incase anyone's thinking of asking,mine are looong gone :blink:
So go for Ragex's
PS, now tuned on a solid 246 rwkws, hitting low 80% and very rarely, heaps of room left.
Great cheap injectors for a very common/obtainable goal
Installation done myself.
Plugged in 82.5% correction on the Power FC hand controller and drove it for ages with no issues.
Felt like normal.
Waited for a few other upgrades to get sorted, dud Z32 Air Flow Meter etc.
Had it tuned by The Hitman in Penrith.
Unbelievable now, love it!
Just waiting to sort the clutch now.. :blink:
I purchased my 550cc injectors from Belgarage. They had them imported from Japan within a few days.
And these babies drop str8-in.
*pats his new s15 480cc injectors*
aye guys i have a bigger turbo plenum and good exhaust manifold high mount, larger exhasut 3inch, and a external dump, adjustable FPR, a vl cat:( 480cc injectors a microtech lt12
pretty much this this motor should be capable of what the injectors can handle yea?
aparently 470hp at the fly, am i being optomisic or just looking for a big BANG!
yep i just referenced it with another fuel injector calulator, ekkk
100% duty cycle is estimated around 270-280 kw @ rubbers
80% duty cycle is estimated around 200kw @ wheels
92% duty is 250kw @ wheels,
meh maybe thats okay, but then again a fpr will draw some more flow out of injectors i was told about 20% more will be gained
so in the same order
100 duty +20% more flow = 540cc = 330kw @ wheels
80 duty +20% more flow = 540cc = 250kw @ wheels
92duty +20% more flow = 540cc = 300kw @ wheels
what do u think
Oh lol for shits and giggles and the myth that they ARE 480cc plus a fpr for 20% more flow being 576cc it will be 360kw @ wheels at 100% duty
thats a tad less than 500hp at the wheels WOW
Edited by ragex
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
