Would engine temp. have any negative effects on the ecu? My problem is that I can start my car in the morning, all is fine until I shut off the car. When I go to restart the car starts fine, but only runs on five cylinders. After about 5-10 minutes of normal (meaning low-boost) driving the #6 cylinder kicks back in and all is fine until I shut off again, then the problem happens again, and again all day long.
Does the r32 ecu have some sort of limp-in mode that would cause one cylinder to temporarily shut down due to heat? I'm getting spark and fuel, compression is solid, but for some reason when I shut the car off for 5-10 mins or so the problem re-occurs. I should also mention that this is an rb20de converted to turbo. I have installed a new fuel filter, Walbro 255 lph pump, 2.5" cat-back, and a 92' civic cold air intake, there is also an AFC NEO thrown into the mix as well. I have replaced coils, ignitor, plugs, wires, CAS, and injectors. The A/F ratio on my guage reads about 14.7 @ idle and as low as 10.5 under boost. The problem also occurs whether my NEO is activated or disabled. The TPS is set @ 4.9. Fuel pressure @ the rail is 40-45psi. I have also made a feable attempt at playing with the CAS to see if that helped, but no change. I am currently running a stock RB20DET ECU. I have been to THREE different mechanics and they couldn't figure it out either. I still have the DET long block in my garage, would I be better off to lose the low end torque and go with the DET block instead of a converted DE block? Anyone with ANY ideas will be greatly appreciated.
Edited by feyd182
https://www.sau.com.au/forums/topic/175373-weird-problem/
