Ok guys. so as most of you know i have had a meriod of little issues, in regards to cold starts and stubles at low rpm high boost and low TP%.
HOWEVER also added to that my fuel ecconomy is shocking. It's down to 250 km per tank. That sux, use to get atleat 350 or more.
The 02 is good, tried a new one made no differance. Tested for vac leaks can't find any, vac at 17mm HG at idle where is use to be always.
My new splitfires come in today as my old ones got fried, so that might help a little, and the car is getting retuned next week.
But surely you can't use that much fuel in a 2.5liter engine.
I run 15 psi boost, all town driving, exhaust is free, no leaks in exhaust and so forht.
Does anyone know if i take out the sensor form the cat, will that improve economy at all.
  • Replies 69
Hopefully the tune will sort it out...otherwise, stop driving sideways!!
That eats the fuel everytime :w00t:
Side note... looking at your signature.
What's a Central 20 ECU, and depending on what it is, why do you need an SAFCII if you have an ECU??
Central 20 ecu is an ecu that can be remaped for an R33, which Dr Drift can now tune and provide chips for. The SAFC II is in there mainly as an additional ready out, as i had it on the car when first purchased with the stock computer.
The car was tuned with the Central 20 ecu and the SAFC II for fine tunning, untill Dr Drift comes down to tas, and i'll get a complete tune.
Interesting to see why my AFR would change if i haven't touched a single thing.
thanks guys
its called flat battery and you lost your map and now its back to the stock map, most likely.
The stock ecu is going "oh shit? wtf? more air? DUMP FUEL! DUMP FUEL!"
Edited by Pauly33GTS-t
Green contacts? make sure all your plugs aren't getting build up in them. Use the contact cleaner in them.
All I can think of is:
AFM
O2
Green contacts
Fouled plugs
Blocked cat (can that cause richness?)
ECU is running mega rich
Atmo BOV
Water Temp Sensor
You haven't got an FPR that's turned up to some insane psi?
But you've already ruled some of those out.
Does the car still pull hard?
When driving and you back off the throttle does your boost/vac gauge read -20mmHg?
And yes a RB25 can be that rich. My bro had a CA18DET silvia and it did just under 300km to a tank regardless of driving style.
But if its a remapped/chipped ECU, shouldn't the map be hard wired in, or in other words burnt into the chip? Thus requiring another burnt chip in order to do another remap?
well the car pulls like a scoldered cat, makes massive power, well feels like it anyhow.
Yeah a new chip is required everytime you need a new tune. Read only chips.
in regards to
AFM - cleaner replaced ect- no go
O2 - replaced, checked working all ok according to consults
Green contacts - humm what, bad contacts, i cleaned most i think
Fouled plugs - new plugs used tried a few different heat ranges ect, no diif
Blocked cat (can that cause richness?) - humm cat? now where did i put that.
ECU is running mega rich- possibly that is next weeks check
Atmo BOV - nope stock
Water Temp Sensor - checked values and cosult, appear ok.
You haven't got an FPR that's turned up to some insane psi? nope but if i do makes SFA differance, have had it at 70 psi.
When driving and you back off the throttle does your boost/vac gauge read -20mmHg? YEP SURE DOES.
Well PFC are esentially what i have but the chip is a hell of a lot more expensive, my chips cost $5 ea and tune time,
Was your car tuned by Dr Drift the last time he came to tas? Have your mods changed since then?
Edited by KeyMaker
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
    • Yes, a plan for non-action is always my first sort of plan! I'm happy to see what falls out of invision's update. I had been having some thoughts on what to do with this the other day and they all seem to have fled my memory, after various solar panel induced traumas, squeaking suspension sphericals, etc etc, over the last little bit. I'll try and recall what I had in mind and make sure that I put it into print in some form before the Alzheimer's strikes again.
    • The ability to have both a 5500 stall for launching, and a regular lockup for every other scenario is pretty sweet. Does it actually work well like that though in the real world? Would it hold up to track use and otherwise you'd never know you had a stall converter in it? If so, that's awesome
    • The thing is, once the content has been tagged we can chop and change the end result as much as we want. Its identifying the content in the first place that needs to be done regardless of the final outcome.
    • Sorry @GTSBoy I thought I'd replied here. There's a new BIG version of invision coming out soon, it might be worth waiting until that happens as it contains a lot of improved functionality for tags. My suggestion would be to add a top level page (not thread) with some info on it and then link to sub pages for various topics. We could even just start really simple with 2 or 3 pages underneath it. Those pages could just have a view (like a pre configured search result) of the tags we choose to put on it. We could have some background or an intro on each of these pages. My only issue is that while admins and mods can update the existing content to contain the tags we want, new posts can have whatever tags the author wants. That said, the reason our tags are so messy is because of that, so maybe we restrict tagging to admins/mods in edits.
