To answer first querstion I live in SE London UK
Also sorry but the spec did not upload which is as follows
Origonally an RS Four V now has a RB26 engine with manual gearbox with uprated clutch
Engine (at present)
Standard plus apexi power induction and elbows. Has front mounted intercooler with HKS hard pipes ,Aluminium radiator (big) and seperate front mounted oil cooler.
Exhaust - HKS downpipe with decat pipe and custom 3 1/2 " straight through exhaust that has been done to take a GTR pattern rear box.
Car was dynod yesterday (not for pub talk but to decide where to go next) On 0.7 boost gave 330 bhp which was abouit as expected.
Engine runs with perfect oil pressure no knocks etc. It was running lean at peak revs so it is getting an uprated fuel pump which will be done in two weeks time when it will also get an HKS EVC5 and either a power Fc or hks equivalent. Should then be good for around 425 bhp and even on raised boost should not overheat as it runs nowhere near hot at present.
It has been lowered and has EL Sport suspension . Will be fitting gold brembos ( from R34gtr) front and back on saturday. These are from my other Stagea so all mods have been done already. Unfortunately there is no way the existing enkoi wheels can be used because of the offset so will be swopping the wheels over as well which are 17" Advan model 7 wheels which have new goodyear F1s. (235s) These will be changed for some LM1s when or more exactly IF I can find some.
I am told bodykit is Nismo and the kit and it is identical to the mustard Nismo stagea thats on the web . This is apart from front grille which is being arranged and the front indicators which are to low for the UK so have been changed
Colour is the pearlescent mettalic green that flips in the light to black/dark mauve.
Interior - Front seats are charcoal/grey recaros and have done the rear seats and door panels to match . It has a Custom 6 speaker sound system with 4 chanell amp and Sony multifunction head unit this has twice as many modes as I can cope with This was fitted in Japan. Also apexi el 2 electronic boost guage . Speedo has carbon front and blue backlighting.
Other mods Polished alloy breather / windscreen washer tank which is where battery was. This has been moved to the back.
Actually one of my favouite mods as the standard battery it exactly the right size to fit in the compartment with the cover above the rear nearside wheel . Or it was once I had modified the existing plastic box, It is also only a foot away from the main rear earthing point of the car which of course helped.
I will post the dyno results as soon as the other mods have been done.
Edited by RSVFOURUK
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
