his price is fair, where the hell did u get 150 for one from? find the link/thread.. sounds like bullshit 2 me :nyaanyaa:
i just did google search n u can tell from the following link his price is well n truelly reasonable.
free bump.
HERE
https://www.sau.com.au/forums/topic/175406-fs-nokia-8800/#findComment-3222676
thanks Sexual 300
3RAR- his phone is 2years old in poor condition as mentioned in the post we arent comparing apples for apples here, mine still has 12mnths warranty and is in top nick.
FYI 88" Serious Nokia's dont come down in there recommened retail price as they are classifyed as a premium handset which hold there value better. So no point waiting for these to drop prices at the shops because it simply doesnt happen Nokia dont lower the buy price on these even when they start getting older.
https://www.sau.com.au/forums/topic/175406-fs-nokia-8800/#findComment-3224230
>.< always happens searched the forums for a good pick up on an 8800 ending up opting for the sirocco at retail price >.<, as said this phone is pure class, the quality of work that goes into this phone almost puts ferrari to shame.
https://www.sau.com.au/forums/topic/175406-fs-nokia-8800/#findComment-3226450
i had simalar phone, 100% brilliant. battery life bad, always charging the thing, however the scirroco is the posh end and never suffered crap battery life,
dunno where you heard that from, i sell phones dude so i know what the return rate is, they also come with 2 batterys and a desktop charger, the battery has above average talk time on it comparing to current handsets on the markeet
btw both the silver 8800 and sirucco have the same internals and battery's BLX-5
Edited by sliksilvia
https://www.sau.com.au/forums/topic/175406-fs-nokia-8800/#findComment-3245090
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
