hey all,
im new to this.. but ahh.. hi my names alex.. from old melbourne... umm... i have just bought my first skyline after a long anticiptated wait... so happens i found a r33 gts-t on car sales which seemed to be awsome (dont they all) after all the phone calls i headed about 4 hours from my house to meet the guy... the car looked and sounded grouse... after a mechanical check by racv sayin the car was in good condition we followed on to buy it.... claiming its 300rwkw.. with a new series 2 engine and a t04e garret turbo sitting on custom headers with a front mount and custom throttle body and a whole lot of other mods... i began to drive the car home with me old man to find about 5 minutes into the drive the car was blowing intense blue smoke.. i babied her home and got her to our mechanic to find that the engine is completely rooted and the compression test that racv gave us was complete bull dust aswell... so turns out i need to bung a new engine in her.... i was wondering if anyone had any suggestions about places to go in melbourne about dropping in a new motor, transfering all the mods across and maybe doing some more perfance at the end... like forge the pistons and stuff like that.. what should i do/?
https://www.sau.com.au/forums/topic/175433-engine-transfer/
if i was you i'd be looking at RACV to fork out for the repairs. the whole point of them is that you buy a car with the assurance that its fine. if they cleared the compression and it was actually crap then you should go to them and tell them to fix it.
thats how the NRMA checks work anyway.
https://www.sau.com.au/forums/topic/175433-engine-transfer/#findComment-3215035
yeah when I got mine checked over I remember seeing something about a warranty on their work or something
Id be looking on the website etc to find if they had some sort of warranty
here I had a quick look for you
http://www.racv.com.au/wps/wcm/connect/Int...le+inspections/
30 day mechanical warranty by the looks of it
Edited by Haines
https://www.sau.com.au/forums/topic/175433-engine-transfer/#findComment-3215109
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
