  • Replies 157
yeah im going unless wsid cancel it again. I was a bit disappointed this week as left work early, changed the wheels, took out the spare and everything out of the boot and get there to see it cancelled for wind, but it wasnt windy at night...
there will be a massive turnout but im still heading out there....i want to get my 12 second run....
https://www.sau.com.au/forums/topic/175434-wsid-117/#findComment-3215920
So is everyone still going to this?.. i'm worried if i waste my time changing tyres its gonna rain again <sigh>
forecast says SHOWER or 2
when is it ??
how much is it to drive on track ?
is it drift or strip times ??
i have never been b4 so as much info as possible
cheers..
https://www.sau.com.au/forums/topic/175434-wsid-117/#findComment-3222437
aparently its going to clear up soon and then be fine for the rest of the day....still keen as but waiting to see if the weather falls in line.....it better!!!!
im heading home before to change wheels if its fine....suppose thats the luxury of living fairly close to wsid....fingers crossed again ppl!!!
https://www.sau.com.au/forums/topic/175434-wsid-117/#findComment-3223065
Yeah - I don't think I will be able to make it now. Am not 100% happy with the car, so will get some little things fixed up first.
Had a tune after increasing the fuel pressure and getting new 4.5" exhaust on - and making more power now, but there is a little lean spot in the rev range according to the Wideband 02 - I can drive around it on the street - and it's only when off boost and low in the rev range - but want to get it fixed before I go hammering it ;)
Also have a slow leak in the left hand front tyre - so need to get that fixed - Don't want to get out there and have a flat - space saver wheel doesn't clear the big brakes on the front - damn it - you learn the hard way hey....
https://www.sau.com.au/forums/topic/175434-wsid-117/#findComment-3223200
    • Interesting....can't say I've ever checked it, have always just changed it in the off season as practice
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
