  • Replies 157
yeah im going unless wsid cancel it again. I was a bit disappointed this week as left work early, changed the wheels, took out the spare and everything out of the boot and get there to see it cancelled for wind, but it wasnt windy at night...
there will be a massive turnout but im still heading out there....i want to get my 12 second run....
https://www.sau.com.au/forums/topic/175434-wsid-117/#findComment-3215920
So is everyone still going to this?.. i'm worried if i waste my time changing tyres its gonna rain again <sigh>
forecast says SHOWER or 2
when is it ??
how much is it to drive on track ?
is it drift or strip times ??
i have never been b4 so as much info as possible
cheers..
https://www.sau.com.au/forums/topic/175434-wsid-117/#findComment-3222437
aparently its going to clear up soon and then be fine for the rest of the day....still keen as but waiting to see if the weather falls in line.....it better!!!!
im heading home before to change wheels if its fine....suppose thats the luxury of living fairly close to wsid....fingers crossed again ppl!!!
https://www.sau.com.au/forums/topic/175434-wsid-117/#findComment-3223065
Yeah - I don't think I will be able to make it now. Am not 100% happy with the car, so will get some little things fixed up first.
Had a tune after increasing the fuel pressure and getting new 4.5" exhaust on - and making more power now, but there is a little lean spot in the rev range according to the Wideband 02 - I can drive around it on the street - and it's only when off boost and low in the rev range - but want to get it fixed before I go hammering it ;)
Also have a slow leak in the left hand front tyre - so need to get that fixed - Don't want to get out there and have a flat - space saver wheel doesn't clear the big brakes on the front - damn it - you learn the hard way hey....
https://www.sau.com.au/forums/topic/175434-wsid-117/#findComment-3223200
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
