  • Replies 157
if you want me to find a new home for ur mickey t's im sure i can give them a new home....
yeah slicks give a me 0.350 seconds.....on an old set.....new tyres would deffinitely be more stickier.....
make sure they are heated tho....my first run felt like it was on ice......
Ray if the weather is good i will also be heading out next week.....0.180 to go.....
https://www.sau.com.au/forums/topic/175434-wsid-117/page/3/#findComment-3226814
Im heading out again....taking tomorrow off to save the rush....
hopefully it aint too windy, i heard that it might be windy tomorrow....
cold temps are great.....squeeze a lil more boost and more power....
https://www.sau.com.au/forums/topic/175434-wsid-117/page/3/#findComment-3233180
i feel ur pain....
I want to move up 2 spots....if i pull off a 12.900 i will be one spot behind ray....but that like .4 and about 20-25kw...
to do this i need to sqeeze an extra .28 which is a massive ask....
i want a 12 tomorrow night....hopefully i dont blow a turbo trying......
guys is there a way i can check to see if my turbo has been hiflowd? with out an expensive pull apart...
https://www.sau.com.au/forums/topic/175434-wsid-117/page/3/#findComment-3233230
LoLz Mona you know the longer you stay away the harder it is for you maintain your position :domokun:
YOU NEED TO GET BACK DOWN THERE GAL! i wanna see those MONSTER BURNOUTS! i still can't do em <sigh>
Changed the front wheels back to normal(after trackday) last night Soo COLD then went to get petrol no v-power racing ffs! next time i'm getting it tuned for 98octane i'm so sick of paying 30c more for 100octane and having no supply available 95% of the time.
Hopefully can get petrol in the car tonight otherwise i'll be out i HATE SHELL!
https://www.sau.com.au/forums/topic/175434-wsid-117/page/3/#findComment-3233273
LOL!!! i'll get you gadget!!!!!
hahaha.. i know!!! but my car needs to be bedded in properly!! and i want my mechanic around for the first time out on track if not drags! so i'll still be awhile!!! and here i thought i'd be back into it by july! lol!!!!
sif not be able to do burnouts! they are soo easy ;) i'm sure i'll have forgotten how though! i'll be back to the stalling! lol!!!! i have rubber to burn too! woooo :P
and pft!! ultimate ftw :D
https://www.sau.com.au/forums/topic/175434-wsid-117/page/3/#findComment-3233308
Brendan.. don't talk about wakefield.. EVERYTIME i go out there i'm getting SLOWER and SLOWER its pissing me off.. i think i'm just getting too old and scared of corners haha. OR i need new tyres..
Yes 13.1 with T1R's not nittos/mickey thompsons then still T1R's 12.9 with a 2.0x 60ft i have a feeling i'll might back in the 13 barrier on wednesdsay because i have my hard suspension on i dunno how it will go.
anyways hope the weather holds up and see all the skylines there.
https://www.sau.com.au/forums/topic/175434-wsid-117/page/3/#findComment-3233373
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
