  • Replies 157
Thanks...
nah on very bald and old set of nittos....but when i heat them up with a decent burnout they are super grippy...
the 1.911 launch i completely changed my technique....increased it from 3500 to 5500-6000rpm....tried the two stage clutch and it felt soooo much quicker....
i used to hit it pretty hard and thats why i could only launch at 3500 cause any more would just bag up off the line....
tried the new technique and didnt even get it perfect and smashed my 60ft time....
https://www.sau.com.au/forums/topic/175434-wsid-117/page/6/#findComment-3237426
Cheers!!
Tried the technique u explained to ray and loved it...first try at it i smashed my best 60ft...
Which technique? Adrian PM me if it's a secreat I wanna know lol
We'll I changed my technique last time at the drag day and smashed my pb/60ft by half a second twice in a row then it rained out !! :ninja:
woooooo Vic!!
No hmmmmmz'ing
I'll drag ya! woooooo :ninja:
https://www.sau.com.au/forums/topic/175434-wsid-117/page/6/#findComment-3237688
My car makes a bit over 200kw....maybe a lil more cause i increased boost a little bit.
dont know if the car gear is a waste of time....if its already at its optimum it will be $300+ wasted...
but practice is whats helping me the best....been just 2 weeks in a row and keeps getting quicker...
https://www.sau.com.au/forums/topic/175434-wsid-117/page/6/#findComment-3237783
Black...someone said it was gtst....benm had a chat to him i think....
think it was this guy, first run he ended up on the other lane.....scary!!!
the guys name is marko its a black 32 gtst with a rb25 it has gt 35 40 and nos not bad at all for a stand engine well done
https://www.sau.com.au/forums/topic/175434-wsid-117/page/6/#findComment-3238044
an update on my first 1/4 experience. think I was the only R34 there.
"consistent" disastrous 60ft time!
1, 4000rpm launch wheel spun all the way through first gear and most of second.
2.5 60ft, ET 14.3 @ 108mph
2, 2500rpm launch (had a chat with Ben and was suggested to try with lower revs) bogged down big time
2.6 60ft ET 14.1 @ 109mph
3, best of the night 6000rpm launch, clutch back in as soon as I felt spin and then out (dont know what exactly happend happend all too quickly)
2.6 60ft ET 13.7 @ 111mph
had to go to the city afterwards so only had 3 runs, but highly doubt i would have improved on the time had i stayed. conclusion was that it was an exciting first drag experience and I have no idea how to launch this car! :D
now can anyone explain the 2rismo 2 staged launch techique (I would pay you to learn it :D )
https://www.sau.com.au/forums/topic/175434-wsid-117/page/6/#findComment-3240000
Forged: was your car the Silver r34 gtt?
2.5-2.6 60ft is SHOCKING,
How much power does the dyno say your car makes? 111mph is quite high
What brand/size rubber you running on the rear?
Did you try lowering the tyre pressure for the rear tyres and attempt to do a decent burnout to heat em up?
Usually for someone with those 60fts, what you should of tried is just a normal take off (as you would do on the street) and i reckon you would of gotten better times, then trying to launch it at this rev or that rev because the tyres weren't up to the task. It happened with one of the guys in an r33 gtst he was trying this and that and his BEST run of the night was when he just drive it off the line as per normal as if he was on the street :D
https://www.sau.com.au/forums/topic/175434-wsid-117/page/6/#findComment-3240039
yeah the silver one was mine. i saw a few white 33s there but didnt get the chance to talk. which car were you in?
it makes a bit over 250kw on the dyno so i was expecting much better times. obviously something wrong with my technique.
tyres are bridgestone s03n 255/17 at the rear. i lowered them to 24psi but did not do any burnouts been told they(burnouts) are ineffective with street tyres.
ive tried a normal take off which was my second run, launched with 2500rpm (as what Ben told me to try) it bogged down intially then as soon as it hits 4000-4500rpm (full boost) wheel spin began again until second gear :D
https://www.sau.com.au/forums/topic/175434-wsid-117/page/6/#findComment-3240163
    • PRICE  : $1400 LOCATION   : NSW Central Coast FIT  :  All Nissan 350Z type Z33 and Infinity G35 Coupe. See delivery note. Hi, brand new, unused, still in the box.  ($1850.00 is what i paid ) My bad luck !!! I thought my right front  Bilstein was cactus so i bought the ST 's to replace all.  Turns out the right front is fine ( loose mounting after service  by a well known importer of Bilsteins ) So im selling the ST's. They are made by KW ( no intro needed ) . Iam on the Central Coast and im willing to meet up in Sydney metro, within reason and Newcastle.
    • Yep, yeah would need to do the flywheel although the 6 bolt NA clutch can handle a 20de if just wants to replace the stocker.
    • No it's fine. Heat sleeve is a thing. With oil running through it it is unlikely. Engine off heat soak can be a thing though. There is no way that you have a leak through the hose. That has pressure behind it and any small hole will turn into a large one in very short order. It is so much more likely to be leaking from the connection.
    • Really? That's piss weak. I didn't know they hobbled the shitboxen that badly. OK. So probs need to buy a flywheel too. But that's not too bad.
    • Hi all. I already posted some newbie-ish questions here and there but this will be my first "big" post. Last summer I went and fulfilled a kind of childhood wish, because I just thought I needed this experience in my life no matter what. The car I bought is a mildly modded 1995 BCNR33 Vspec. It was repainted to a metallic orange color all around and it had all windows reseated. Not so well done black respray in the trunk and a metallic black in the engine bay. From outside it looks very nice except for a minor paint error on the roof and the rear spats needing new adhesive tape. The inside is pretty clean and no broken plastics, missing or faded buttons. Even the adjustable mirrors and trunk antenna work like a charm. Despite a moderately long list of issues I don't (yet) regret buying this car. Most mechanical problems are just due to age, like worn rubbers here and there. The underside sadly has lots of corrosion, especially to the back. It looks like it either has been driven in the winter for a while or it lived near the saltwater in Japan, the rust is nothing terrible but it'll require to be looked after. Mostly panel gaps and all the mounted components underneath are a bit crusty, but I don't think anywhere has progressed so badly that there's going to be holes. Front right jacking rail is crushed and needs some care so it doesn't develop into a rust crater at some point. Worst part is definitely the strut towers. I thought they looked fine but after taking off the strut bar I noticed that it actually started bulging up on the passenger side. Probably would have passed on the car or negotiated down by some thousand Euros more if I had noticed this before buying, but here we are. Trunk area also has signs that there was a water leak to the interior once but nothing too crazy, I guess lots of Skylines had this at some point. As for the list of (known) issues, I'll try to make this compact. I hope the coloring is self explanatory. Mechanical: -Various busted or soon-to-be busted rubber bushings and ball joints. Will replace ball joints with OEM or better and bushings with polyurethane where possible. -Shaking steering wheel at above 80kph -downshift from 5th to 4th is a bit crunchy unless I rev-match, might just try to renew the shifter assembly, but it's not a priority issue -tailshaft centre bearing could use a replacement, is it worth going 1-piece tailshaft as it doesn't look too fresh all around? Chassis: -underbody corrosion on many spots and in hollow spaces, needs to be treated -corrosion on many bolts, hoses, lines, suspension components, subframes, will be treated when replacing of the bushings is needed as time goes on -strut tower top panels and some of the surrounding panels are rusty, so needs fixing. Will look into doing this with a buddy in the winter, otherwise bite the bullet and pay a professional -driver side door is misaligned to the body and needs to go a slight bit more inwards -both door windows are misaligned and have an airgap where the window meets the door at the B pillar -The Aerocatch latches for the bonnet have locks but no keys, need new keys. -driver side door window is kind of gritty and could use a polish -damaged jacking rails and front frame rails, from people lifting the car the wrong way, might have this fixed by a bodyshop Electrical: -Nismo tachometer is just bouncing and displaying nonsense, supposedly worked fine when the stock ECU was still in the car -An old Greddy boost controller sits on the dash which will be removed as it servers no purpose anymore. -a led segment rpm gauge is on the steering column, will probably also be (re-)moved once the Nismo tacho is working correctly -there was an attempt to make the sound system better by the previous owner but it was just inducing noise all the time, ripped out the amp and filters in the back, no music for now -trunk antenna goes up as long as the radio is on regardless of the mode, I want it to only rise if I choose Radio specifically or per switch -3rd brake light is a bit dimmer than the taillights but everything was converted to LEDs so mabye now it just seems dimmer? -reverse light flickers, have to test if that behavior changes when I fiddle with the gear stick. Hope I can get around changing the switch. -Left side taillight, blinker section has minor water intake and is humid after washing. Other side has a hole in it, probably for that exact reason. I'll probably reseal them entirely and plug the holes. Engine: -minor coolant drips on one or the other hose -rear turbo leaks oil onto the exhaust making the car essentially undriveable due to fire hazard -Oil filter relocation kit has an oil drip at the Dash lines, will probably make a new connection there and tighten real good and pray -throttle body assembly is slightly stuck for the first throttle pedal input after sitting for a while I'm always open to suggestions and advice from more experienced people, I'm sure half of this list is easily dealt with and just requires some time and effort to sort out properly. Once I have some proper pictures of the car I will post some in this thread, I just have to remember to take some more once I get the chance to. Will post updates when I have news on anything, I want to try to keep this thread as kind of a logbook as well. Ultimately my goal for this car is to just enjoy it. An engine rebuild is probably going to happen sometime as well, because it is old after all. It will never be fully new again, I am just not that rich. But I want it to look good, work well and not rot away while I drive it. I'm probably gonna spend a lot of money on this journey, hopefully not an unreasonable amount.
