hehehe... thats an awesome first attempt though :D getting the 60fts down is the hardest thing i reckon! i usually range from 1.8 (best run) to 2.2... i dread going back out there cause i'll be back to square 1 :D
i do want to know 2rismos technique :D all i remember doing it slipping the clutch a lil then all hell breaks loose! lol!
https://www.sau.com.au/forums/topic/175434-wsid-117/page/7/#findComment-3240171
  • Replies 157
Lolz i was in ONE of the 3-4 of the White R33 Gts25t that night with GTR32 rims up front and 300zx (z32) rims on the rear and the BIG white HKS sticker across the windscreen.
you should of done the burnout, still helps on street rubber just no need to do a monster SMOKEY one. (cough) but seems to work for Moanie on her street rubber(cough) sub 2.0 60ft on 225 federals ey.
https://www.sau.com.au/forums/topic/175434-wsid-117/page/7/#findComment-3240230
lol!!! for me its not so much the warm tyres as its for the smoke show.. think after all the stalls and bad attempts, i revel in the fact that i can do a semi decent one :laugh:
I miss my sig :domokun: what happened to it :(
https://www.sau.com.au/forums/topic/175434-wsid-117/page/7/#findComment-3240316
yeah the silver one was mine. i saw a few white 33s there but didnt get the chance to talk. which car were you in?
it makes a bit over 250kw on the dyno so i was expecting much better times. obviously something wrong with my technique.
tyres are bridgestone s03n 255/17 at the rear. i lowered them to 24psi but did not do any burnouts been told they(burnouts) are ineffective with street tyres.
ive tried a normal take off which was my second run, launched with 2500rpm (as what Ben told me to try) it bogged down intially then as soon as it hits 4000-4500rpm (full boost) wheel spin began again until second gear :laugh:
rubbish.smoke thosse tyres up.the tracks coating reacts to a tyre's heat.
i went half a second quicker after i smoked the tyres good.learn how to do a burnout starting in 2nd gear.it wont break anything.just dont go dumping it like you would in 1st gear.prolong the burnout.
you should be able to get much better grip off the line.but another thing.dont just dump it.
if you have a dyno sheet have a look at where the torque of the engine kicks in and or when boost starts to ramp on hard.launch just below that so at least the car is in motion when your power really starts to kick in and you should feel it give you a harder shove in the seat than you have previously experienced because your not wheelspining your tyres are gripping.hopefully :domokun:
and if you can get you head arround to slipping the clutch and feeding the acc on the launch to reduce wheelspin thatd be the way to go also.you will find less wheelspin and faster times.
and get quick as u can.smooth gear changes.
https://www.sau.com.au/forums/topic/175434-wsid-117/page/7/#findComment-3240453
Assume most of you guys are using drag radials? If so, what tyre pressure are you running?
Drop them down to 13-15psi if you're not doing so already. Add in a decent burnout (2nd gear) and launch the car by slipping the clutch from 5000-5500rpm (2rismo assured me I wouldn't break anything by doing this and I'm happy to say I haven't done so yet :D ) and you should see an easy 1.8** 60' time or better.
Takes a bit of practise and I've stuffed it up enough times to know, but when done right, there's nothing stopping you from dropping all the way to 1.6** 60'.
Save a tenth at the 60' mark and you should drop at least 2 tenths off your ET :)
https://www.sau.com.au/forums/topic/175434-wsid-117/page/7/#findComment-3244390
GooD luck CHris! remember:
-remove spare tyre+tools/jack
-1/4 tank of fuel
-lower tyre pressure to 20-25psi
-NICE BIG BURNOUT FOR MOANIE!
-DRIVE IT LIKE YOU STOLE IT!<as 2rismo would say>
ooh and skip dinner too for less weight :)
https://www.sau.com.au/forums/topic/175434-wsid-117/page/7/#findComment-3249168
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
