Hi Guys'n Gals
would anyone be interested in a SAU social dinner next friday?
I'm going to call the Earl Of Leicester tomorrow to inquire about some tables ect (some where a bit different to the Ale house) Unless someone else knows of a good bar/ restaurant centralized with lots of parking.
I will also be looking into another bowling session if people are interested. I know we did it last time, it was good to be able to sit and socialize with a beer or two (a bit hard in a movie or something)
I can always push the date out if it is to short notice
Cheers, Nick
**COMING**
Whiplash
Heslo
Astro?
BigMonkey
Evil34 +1
Kalel
Kroozin
PkBlade
Pokie
*flick*
Luke
Oosh
BlueGTS?
dnbutts?
Madaz +2
Fishpaste
Edited by Whiplash
https://www.sau.com.au/forums/topic/175466-sa-social-dinner/
  • Replies 91
Posted Images
hey hey,
i'm a newbie.. and would like to meet a few people who have owned a skyline for a while and can recommend a few workshops i can visit with my new investment.. get to put some faces to the nicknames i see on these forums as well.. fri 13th sounds good for me...
cheers, tushar
Gonna be in Melb at Sandown that weekend............So count me out!!
I was going to the VMRC round aswell but had to postpone my trip to the next week. You there with the karts again?
OK i'll wait a day or 2 to get a better idea of the number of people then make a booking.
Will the bowling be OK with everyone if so i will try and get a lockin like PK did a few months back
Ash will be good to catch up again been a while since shutzenfest :)
Edited by Whiplash
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
