Hey Guys, i've got my car up for sale, but i have been asked a couple of times wether i would seperate my new engine/turbo package. So here's the details.
CP Forged Pistons, Eagle Rods, Tomei Metal Head Gasket, All New Nissan Gaskets, Extensive Head Work, Head stud kit, N1 Oil Pump and Collar to suit, N1 Water Pump & Nismo Thermostat, HKS Step 1 Cams, HKS Cam Wheel, Z32 AFM, HKS GTRS Turbo, 555cc Injectors, Bosch Fuel Pump, Split Fire Coils. There is alot more that has gone into it, but this should give you an idea on the kind of quality parts that have been used. For exact specs on head work or any thing else please call me and i can put you in touch with the workshop who built it. I have spoken to many people with a similar setup who have 300rwkw on a sain amount of boost, so that is my aim. The above work/ parts cost me 20K,( with receipts) and has an engineers cert to boot.
Still just running in, so is available to hear/see running in my car. May also negotiate other components from my setup.
Price Looking for $10k + your old motor and turbo (must be running etc)
or $12k outright
https://www.sau.com.au/forums/topic/175478-complete-built-rb25-800ks-old/
Have a couple of people interested. But nothing solid yet, so still here waiting for YOU!!!
This is a guaranteed 300KW ATW package. Just ask thizzle on these forums, i've followed very closley followed his formula for sucess......Come get it..... :nyaanyaa:
or $12k outright
hey
interested in selling just the bottom end with n1 oil and water pump, tomei head gasket?
send me a msg or call after 5:30 if you like, im keen depending on price
interested to know what price (if seperating) for block and head itself. Dont need injectors, plenum, turbo, coil packs, exhaust manifold.
Thanks
Second that (but I want injectors)
Thanks
if you decide to separate, interested in the turbo if it's only done 800k and it's reasonably priced
keen on injectors and splitfires also if only 800 k old and of course the right price.
Cheers
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
    • okay, so I figured this out, removed needles and reinstalled after swapping the gauge face on my triple gauge for my ER34, all work and look good. I tried to do the same for the main cluster, but the main cluster gauge faces are dished, the replacement gauge face are flat, so due to the dish in the org face ,mounting backing plate (clear) and depth of the needle, the flat gauge face will not work. I notice that R34 gtr gauges are flat, appears to be different clear backing plate that aren't dished. are these available, or what have others done to install flat gauge faces?
