Howdy people.
I no longer have a use for these parts. I was going to do a turbo conversion but the car's gone now. Here's a photbucket link http://s164.photobucket.com/albums/u1/RPDsnooze/. Yes I'll ship around the country, at your expense. Choose carefully as I am not a retail shop and therefore don't refund if it's the wrong colour... I recommend you ask questions and/or come look at the items to decide for yourself. I'm located 5 minutes south of Brisbane CBD.
RB25/20 Turbo wastegate actuator - $25
T28/T3 Genuine Nissan Turbo from RB20DET (R32) - also VGC, original, 70,000kms old. - $99 This turbo is too small for the RB30 motor, if fitted would restrict flow, better suited to something around the 2Litre engine size.
Oil temp gauge (internal, needs to be mounted in cup or flush with dashboard). - $15
2 stage boost switch solenoid. - $25
Set of four original S3 Silhouette center caps from factory alloy wheels. - $25
See pics http://s164.photobucket.com/albums/u1/RPDsnooze/.
PM me or call on 04171 94005 (Rod).
Cheers
Rod
Edited by SNOOZE
im interested in the t28 for 140. im on the gold coast so i can drive up :) ... what boost is the wastegate actuator running at on the r32 t28?, thanx
VL Turbo brass oil drain connector for block. - $15
RB25 crossover pipe with stock blow-off valve. - $45
I'll take them if you still have them, theyre needed for the hybrid conversion. Im in the brissy area, so can pick up.
Sms me if you can, im not on here much. 0422418299
Thanks mate.
Dave.
Does the R33 Turbo have the elbow or actuator? And willing to post?
Hi NathR32
Sorry for the late reply, it's been a crazy weekend.
I am willing to post, and that turbo doesn't have an elbow or actuator.
The smaller turbo has the stock metal elbow tho.
Cheers
Rod
im interested in the t28 for 140. im on the gold coast so i can drive up :D ... what boost is the wastegate actuator running at on the r32 t28?, thanx
Series 2, sounds good, the R32 T28 doesn't have an actuator attached to it, but the separate one I have listed was running at about 12psi.
Let me know of a good time for you and we'll meet up.
Cheers
Rod
your inbox cant receive pm's atm.
the oil and water lines you have are they by any chance one to hook up a r33 tubo to a rb20 r32?
Sorry Mahartika they're sold already.
Updating the listing now.
Cheers
Rod
Thanks mate.
Dave.
No worries Dave, the crossover is yours, you were the first to call.
Cheers
Rod
Cheers
Rod
If it falls through i will take the bov.
sorry to hi-jack ur post but if somebuys ur turbo i have a Rb20 wastegate actuator(10psi) for $40
EDIT: $40
Edited by justain
sorry to hi-jack ur post but if somebuys ur turbo i have a Rb20 wastegate actuator(10psi) for $45 plus post.
lol, thanks for that. :laugh:
I believe the one I'm selling was altered to run around 13psi, from what I've been told anyhow.
Choice is always a good thing tho.
Cheers
Rod
    • Ha! well, there's your problem!  Guess the last person in there didn't have great attention to detail....
    • It seems like you guys want to behave like rabid dogs, rather than gentlemen... Knowing one has jumped in on a fellow comrades near done deal, and sniped it at the last second, how can one sleep at night?
    • My wifes says we have a spare set.
    • Good news!!! Changed the O ring today and I’ve got the “pssshhhh” back when I open the fuel cap 😂🙌🏼🙌🏼 It was 100% the O ring because that bloody thing was inside the fuel tank 😂😂😂😂😂 Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But she’s running!!! ❤️
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
