Item: Genuine Modena 3pce Lightweight Jap Wheels with Tires
PCD: 5x114.3
F: 17x8.5 +45 with 225/45
R: 17x9.5 +38 with 245/40
i can throw in some 8mm spacers for free and some brand new spacers for the front, either 25 or 30mm for an extra $100.
see this thread for tyres which can come with the wheels: http://www.skylinesaustralia.com/forums/Sa...le-t181837.html
Item Condition: Good, fair bit of gutter rash but seem to be straight, slight leak in one of the rears, expected to be the valve stem, should be peanuts to fix if u wanted to.
Reason for Selling: looking to change
Price and Payment Conditions: For the wheels by themselves $600, if you get the tyres and spacers i can make them $500 + tyres and spacers, throw me a PM and we can work out a deal.
Extra Info: These were brought in from Japan on a r34, they weigh less than my URAS NS-01's and are wider which suprised me alot. Will consider a swap for some other rims similar to these, not sure what im after yet, just feel like a change.
Pictures:
https://www.sau.com.au/forums/topic/175597-17-lightweight-jap-rims-with-dish/
price change, i forgot to change the price from the copy and paste job i did from another item for sale (for the template), sorry about any misunderstandings, i farked up :thumbsup:
  • 1 month later...
sales fell through, well i think they did, price drop to $800 firm as thats what i had agreed to sell them for to someone, if i dont get rid of them soon im powdercoating the centres black and keeping them :)
will also supply some spacers for the front for an extra $100, brand new, 25mm, 30mm etc
think they might b old school RAYS rims...a friend of mine with a tire shop showed me the other day:D great looking rims but will need spacers to clear brakes in most skylines i rekon
yep very tough looking rim, personally i rekon they would look best on a r31 or dr30 etc, suit the old school lines. should fit over smaller brakes, they fit over my rear brakes but my 4 pot m-spec brakes at the front they needed some small spacers to clear them, i was running them with 25mm spacers and sat very tough but i guess u could run them with smaller spacers if u wanted to. as i said for an extra $100 i can supply spacers.
i like, im gonna look into how much it would cost to get them redrilled to 4 stud and get back to you.
alright no probs.
BTW these come with some centre cap things that go onto the thing in the middle, love the terminology haha.
just called up wheel worx, $50 a wheel to redrill them to 4x114.3
if anyone is interested i could get this done before the sale at the buyers expense obviously.
  • 3 weeks later...
still for sale peps, throw me an offer and i might consider it, starting to get too many rims and dont really have a use for these anymore. at the same time i dont really want to sell these for cheap as they are proper genuine Jap wheels, not some cheap heavy shit that make the car handle like a shit down a slippery dip.
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
