I'm looking at upgrading my R32 GTR brakes as they aren't handling the new power too well.
I'm going to get some good DOT5.1 fluid, braided lines and Ferrodo 2500 pads and I'm looking at upgrading the rotors.
My choices seem to be RDA slotted rotors or DBA 4000 series rotors. The RDA seem to be cheaper but I have not heard of their performance that much, while I have heard stories of the DBA's cracking under hard use.
The car is fairly quick and be used mainly for street use, but driven fairly hard and the street and the occasional track day (possbily at Wanaroo which is very hard on brakes).
What I'm looking for is value for money, in terms of both performance and wear resistance.
Let me know any thoughts.
Cheers
Simon
https://www.sau.com.au/forums/topic/175635-rda-vs-dba-rotors/
If your having brake problems on your GTR, putting replacement rotors on will do very little. Stick with the pads and fluid and see how that goes. If your rotord are undersized and need replacing then i would personally just use the RDA because they are cheaper. Its unlikely that on the street you will pick any difference between a cheap rotor and more expensive. Especially since the 296mm rotors will do a good enough job, but as soon as you start to punt it hard at the track for more then a few laps. no 296mm rotor is going to do a great job
Cheers
Simon
My thoughts:
You can get a set of RBA slotted rotors from the group buy at a fraction of the price of the DBA4000's from any normal outlet.
So irrespective of which may be slightly better (I have no reason to believe the DBA's to be superior simply because they crack from the stupid little return slots on the rotors) they cannot be sufficiently different to justify spending extra money on the DBA's.
:P
Oh and don't bother with DOT 5.1 nonsense. Find a bike shop that sells Motul RBF600 & spend $28 for 500ml. You will fade the DS2500's around Wanneroo long before you boil that stuff. Trust me I know from btter experience.
Edited by djr81
RDA/DBA - Have a look at the Group Buys the RDA deal is pretty special and looking at the RDA rotors I bought they seem as good as DBA .
I would suggest if you are serious about pushing hard at Wanneroo for more than a few laps at a time you will be better off with a more race oriented pad than the DS2500. It is not that hard to change a set of pads over before hitting the track.
The 2500 are a good compromise for road/some track but won't take long term punishment like you are talking about. Loss of brakes at the end of the downhill is a "puckering" experience.
Edited by WRRR
how many laps did you get from ds2500's
with the power im making i'm thinking i wont last more than 3 or so haha
Well it depends on a lot of things - temperature on the day, how much hp you have, how heavy the car is, what tyres you are running, how aggressive you are under brakes, how much ducting you have, stone guards etc etc etc.
DS2500's will be fine for a three lap run, ie warm up three laps, cool down. Which is pretty standard for drive days & lap sprint events.
WOW OUCH!!!
i just got a email from UAS for a quote for just caliper adaptors from 296 to 324mm, i think they must have liked the look of me because they tried to bend me over.
does anyone make them?!?
There is a place in Sydney where we got the brackets to mount R31 calipers & rotors to a hilux diff in a Datsun Sunny. Its called Craft Differentials... they might have something???? 02 9637 1973
WOW OUCH!!!
LOL, sell your GTR calipers and rotors and buy my GTSt calipers with near new DBA 4000 rotors, rebuilt and HPC coated calipers and the 280 to 324mm adaptor. the 280-324mm adaptor is more robust then the 296 to 324mm adaptor, its simply a finction of hte meat afforded by the larger change in diameter
If you buy the adpators for less then $250 then they are a steal
I use RDA rotros (group buy) with EBC redstuff pads, RBF600 fluid and braided lines for my R32 GTR. although i haven't taken it to a track, i do take it regularly to the mountains and i push it hard - especially on the down hill. No problems with the rotors so far and no fade.. now imagine if i had cooling ducts to each corner and suspension :rant:
Yeh $365 seems like a fair whack of money until you consider that the billet they are made form has about 40% wastage. So thats material you have to pay for that isnt ended up beign used. Billet alloy isnt cheap to start with. Then you have time for setup and machining, then tapping threads etc.
So i have no idea how the $180 each is broken down. But consider a machine shop charges for programming and setup time. Then actual machining time. Then materials cost. Then high tensile caps. Dleiveyr between machine shop and seller. Then of course the bloke selling them wants to make a dollar. But thinking about it he isnt making a lot from them.
Anyway, they still work out good value as the 324mm rotor hangs in there a bit longer then the 296mm rotors
    • Some of the filler.   Also if I look under the top flap of metal it starts looking good quite close to the edge. I get the feeling it doesn't go much further.
    • So, I finally started digging at the bit of my roof that was cracking and bulging a bit. Well, it was just thick filler that was covering some pretty bad rust. I didn't find the edges, I was too bummed to keep going.  There are a few holes as you can see. There was just so much filler but looks like no attempt under the filler to prime or use rust converter, just slapped filler on exposed rust.  Anyway, I'm going to take the windshield out and find the edges. I'd love to fix this myself as I'm pretty sure it'll be expensive to get done properly. I was thinking I could just get a cut piece from another E39 and just weld it in place as it would be the right size and shape.  Thoughts?
    • This is the territory of the "Stage 1/2/3 Golf GTI/R" or otherwise off the shelf tune with (relative to before) minor mods. It's easier now. Downpipe and Tune and boom, big increases. Stage 1 OEM+ is where it's at. This is where the niche evolved into and it's really easy to see why. It's rare to even NEED to consider changing turbos or going to aftermarket ECU's or building bottom ends for more power. Stage 1-2-3 will get you a LONG WAY. Civic Type R turbo GR Yaris/Corolla Anything with B58 (MKV Supra/x40i) Anything BMW in General Anything Audi in General Any turbo AMG RenaultSport Turbo offerings Korean Elantra N/I30N Ecoboost Mustangs Focus RS? List goes on. I would argue in the future it won't even need to go on... M3P is pretty rapid out of the box...
    • There is a way, but it's not with the same cars. You need to find the same vintage of car, that we had. Realistically, that was an affordable car with aftermarket parts around. So what people need to find is a car that had a decent base in its day, and can be modified. They're looking for a car year make of 2010 to 2015 really... Aus could have done it if Holden didn't fold as V8 commodores were cheap, and if Ford didn't get expensive thanks to COVID, then you could cheaply play with FG Barras. Realistically, those are just a bit heavier, four door skylines. I'm sure the US and UK have similar cars they could find.
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
