alright, i realized twin turbo setup is not for me or my apllication, im gonna go with a nice size single turbo setup. now im not looking to make more than 450hp to the wheels but i need amazing response like boost at 2800rpm and up making a very nice smooth boost curve. Im going to run a twin scroll manifold with a full T4 60-1 turbo now would this allow me to run a very nice spool and great response?
also what do i do with all the factory coolant/oil lines to the stock turbo? my new setup only requires one oil feed and one oil return.
what is the fitting that i would need to go from the block to an -4an fitting to supply oil to my turbo
what oil return do i use? can i use either the stock front/rear turbo return spots?
where can i get the intake turbo pipe that splits to a "Y" shap to run twin mafs? or is this a custom peice?
oh and the only mods im gonna do is cometic metal headgasket,adj. camsprockets and front mount intercooler
thanks all in advance,
paul F.
Edited by paul f
https://www.sau.com.au/forums/topic/175647-single-turbo-setup-questions/
You can get a T04/60-1 Garrett ball bearing turbo - I think they call them T4R . They are almost identical to A T04Z except they use a T04S 60-1 compressor pn 409535-1 . Can use all the same turbine housings and comes with the same T04S 0.70 A/R compressor housing .
Personally I think for the power this turbo is overkill , the real Garrett GT3071R in twin scroll form can do 440 and if in the US talk to FullRace Motorsport . You may want to look into head work and cams for an SR20/KA24 because the turbo may not do so well on a mechanically std engine .
BTW both the T04S 60-1 compressor and P trim turbine are hardly modern technology and you can do better .
Cheers a .
ok specs ar 4inch inlet 2.5 outlet .60ar cold side, and .80 hot side 3inch outlet and its a wet float bearing im looking for around 450hp but i would like boost to come in as fast as possiable i have a wideband and am going to tune with an safc neo to help the fuel curve a little too! im not looking for something amazing but with decent power but amazing responsise! what ya think?
Mate its going to take far more than a SAFC to make the results youre after
Agreed.
450rwhp/330rwkw
Response around 2800rpm
Only S-AFC to tune
Its all things that just are not fitting together and simply put, will not give you what you want.
If you was blistering response. You'd need a GT30, and that will limit the power to around 300rwkw at best.
You really need a PowerFC, or some kind of decent management.
Also a forged bottom end. You want to drift it and give it a flogging, no stock RB26 will take that with 300rwkw. It will for a while, but it will die.
I dont even reckon a GT30 would come on that low.
Standard RB26s dont come on hard till 3500rpm.
I also agree with Nismoid. 300rwkw, constant 8000rpm and standard bottom end will go bang no matter what motor it is
espessially if you try and tune it with a S-AFC
Its not school holidays in the US is it?
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
    • Set of knee pads for a R34. Will fit every model I think. Comes with everything except the rubber covers for the bolt holes. Still in great condition. You will need to drill holes to mount these or use double sided tape. I can do free shipping and will be shipping from the Netherlands with tracking.
    • Nistune needs something like an entire excel spreadsheet in which you build an abstraction layer that converts everything from real units you can actually measure into all of the various tables. The number of unexpected dependencies hiding in how the Nissan ECUs do math is a pretty impressive optimization trick for 8-bit MCUs but good god is it awful to actually work with in practice.
