***SOLD***
For sale: 1977 Datsun C210 Skyline Coupe
Head has a mild cam, Larger intake valves, and cleaned up ports.
Numberplates MYC-210
Rego till december.
Condition: Fairly straight, But needs some love. Engine has a slight overheating problem which i'm not too sure about. overheats eventually (after around 30-40min driving)
Price and price conditions: $2800 o.n.o
Extra Info: nothing much else to mention i don't think. has had a new head gasket recently.. and a few other bits and pieces. JVC head unit in the glovebox, 6x9s in boxes on parcel shelf.
Contact Details: Mobile - 0402176302
Delivery & Conditions of Delivery: Pickup
Pictures:
Edited by Jono_c210
https://www.sau.com.au/forums/topic/175689-fs-1977-datsun-c210-coupe-sold/
Theres one in sydney with a LS1 in it..
runs pretty good times.
and also a mate of mine has a 4 door one with a RB25 in it... makes my new R31 feel like its standing still..
Love to see one of these done up as a drag car with a VQ45 and Supercharger!
Or Twin Turbos! :dry:
Would look Awesome!!
Or Twin Turbos! :)
Would look Awesome!! EDIT: Maybe like this.....
LOL thats awesome :laughing-smiley-014:
Congrats to the new owner! :-)
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
