Could the age of the fire-breathing sports car be coming to an end? With cars like the Bugatti Veyron and Koenigsegg CCX starting to break the 400km/h mark straight out of the crate and governments around the world continually lowering speed limits in an effort to decrease road trauma, high-speed motoring passion is on a clear collision course with road safety and emission control sensibility. This battle is now set to take center stage at the European Union where parliamentarians are gearing up to debate the merits of a plan that would see new cars limited to 162km/h (101mph) top speeds if they want Euro approval.
http://www.gizmag.com.au/go/7550/
No way, speed limiters will be removed/diverted easy. Only way they can do it is to produce cars that cannot go that fast lol.
Haha I can see the performance car manufacturers backing it...
Theyd only need to make their cars with two gears :P
Cost savings right there haha
But yeah, would be a bit of a joke, dont realistically see it happening
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
    • Yep. Saw that on the image above but, wonder if it makes more sense to clean out the iacv because let's say in theory mine is dirty and if I clean it the rpm will drop. If I first go to my tuner to drop the rpm and then go to clean my iacv won't it drop further or is the rpm a fixed number?
    • Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
    • He still had the suspension dialled in for him! I would have sworn the lowest weight he ever got to was 1300kg though Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛 Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
    • Yeah this isn't a super complex shape, but I was still happy to buy instead of fab version 1; very little in a modern can is a flat surface, and that is true here again - the undertray has about 50mm in height differences that I would have had to work out myself. I will probably make something more substantial before it does any rally, I don't think 1mm steel is too much use as a bash plate. There is also cooling to think about, Z1 have done a bit of development and have some air holes and louvers in the shape, will see how that works out too
