Hi, i am looking to do a auto to manual conversion on my r33 gts-t, now I know this has been discussed several times, but I actually need to know ALL the gear one would need to do a conversion like this (clutch,flywheel, driveshaft etc)
Need to know so I can buy all the parts and get the conversion done locally.
Any help would be appreciated.
https://www.sau.com.au/forums/topic/17572-manual-conversion/
russ, i already considered this, but theres no point ur looking at nearly $3000 for there whole conversion, money is better spent on mods :D, or just sell the car and get a manual :) i just gonna wait till i get my next car :) definately a manual
adrian :rolleyes:
https://www.sau.com.au/forums/topic/17572-manual-conversion/#findComment-366974
  • 4 weeks later...
yeah 2-3kis the general asking price. azn romeo if u ain't got anything productive to say don't say anything!
hippy, yeah it will blow the auto box, but then again u could always strengthen the auto box? hehee but manual is more fun to drive :P
adrian :D
https://www.sau.com.au/forums/topic/17572-manual-conversion/#findComment-415031
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
