Hehe. Pit eh? Can't say I've seen that screen before, but I reset all the service interval stuff mucking around when I first got the car. One of the menus just off the main one has a service interval monitor on it(it's the one with 1500KM on it and graph lines on it) you can reset this through there I'm guessing.
Ok checked it out and yeah it's definitely that menu cause i have it too now!
On the main menu, it's the 3rd menu down on the right hand side.
You can program 4 different service intervals.
It's pretty obvious from there but when you go into each one:-
The first button is the reset the KM's to 0 for that interval.
The second button you can specify the number of KM's it warns you at.
The third button turns that particular reminder on and off.
100% right.
Just reset the servied schedule, those info is just reminder.nothing else.
I have a Scan Gauge II coming from http://www.prospeedracing.com.au/ which hooks up and gives a lot of readings, I haven't used one before so I will see how it goes but it clears codes and heaps of other things.
Info is below and about $230 to $240 delivered.
TRIP COMPUTER
Trip Computers
The ScanGauge II automatically tracks
and stores data for 4 Trips.
The TRIP modes in the ScanGauge II can be used to save gas. Improved driving habits can improve fuel economy by up to 30% according to a US Government source. The ScanGauge II lets you try different driving techniques and routes and gives quick feedback on how they affect fuel use.
» Maximum Speed
» Average Speed
» Maximum Coolant Temperature
» Maximum RPM
» Driving Time
» Driving Distance
» Fuel Used
» Trip Fuel Economy
» Distance to Empty
» Time to Empty
» Fuel to Empty
Scan Tool
Check for Diagnostic Trouble Codes
The ScanGauge II can check for Diagnostic Trouble Codes (DTCs) and if found, can display how many there are and the Trouble Codes themselves.Using the internet or repair manuals, these can be translated to the failed component and repairs can be made.
Data captured when the Trouble Code was set can be recalled to help troubleshoot the problems (was the temperature hot or cold, speed high or low, etc.). The ScanGauge II can be used to clear the trouble codes and data which will turn off the warning (Check Engine, Service Engine soon, etc.) lamp.
Some states now require that vehicle self tests have been completed since the codes were last cleared, before running emissions checks. The ScanGauge reports this "Readiness".
» Reads Trouble Codes
» Reads conditions that set the Trouble Code
» Clears Trouble Codes
Turns off "Check Engine" light
» Tells you when vehicle is "Ready" to pass OBDII testing
» Make and store up to 10 rewritable special codes
to send to the vehicle computer
Digital Gauges
12 Built-in Realtime Digitial Guages
The ScanGauge II can display up to 4 of 12 possible gauges at one time. The units of measure can be changed and the rate of update can be increased or decreased.
» Fuel Economy
» Fuel Rate
» Battery Voltage
» Coolant Temperature
» Intake Air Temperature
» Engine Speed (RPM)
» Vehicle speed (MPH)
» Manifold Pressure
(not available on some vehicles)
» Engine Load
» Throttle Position
» Ignition Timing
» Open/Closed Loop
  • 2 years later...
TRIP COMPUTER
Trip Computers
» Maximum Speed
» Average Speed
» Maximum RPM
» Driving Time
» Driving Distance
» Fuel Used
» Trip Fuel Economy
» Distance to Empty
» Time to Empty
» Fuel to Empty
Scan Tool
Digital Gauges
» Fuel Economy
» Fuel Rate
» Battery Voltage
» Manifold Pressure
» Engine Load
» Throttle Position
» Ignition Timing
» Open/Closed Loop
Sorry to dig out an old thread but did this tool work with the v35?
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
