hey i'm new to this forum so i dno if i've posted in the wrong section but i'm really interested in buying an R34 GT-T, i've read about them n shit and i have heard a lot about bad experiences with imports and modded cars...
Should i import it? Who off?
What should i look out for when i'm buying from an importer?
i want to buy one with NO mods - heard too many bad stories!
How hard is it gonna be to resell?
Read somewhere i can make it a 4.5s - 100km/h car for not so much $$$ - true? (i don't think so)
Best place(s) in victoria to buy/fit mods
Is there anything about r34's i should worry about (like reccurring probs or just shit that always happen with them)
R34 easy to steal? should i get an immobiliser and club lock n shit?
if anyone can answer some of these questions that'd be awesome, also anyone who feels they wanna add more info please do it
Every one of your questions has been answered countless times on the forum. I suggest you take your questions, search the keywords, and read up.
For importing - look in this forum (Imports)
For modification queries - look in Forced Induction
Workshops in Vic - look in the Victoria forum
Alarms - look in the Car Audio and Security forum
etc.
".... I've read about them n shit?"
Get your loan approved first, it'll save a lot of time.
Also, what license do you have. If you're on P's, forget about an R34 turbo.
Oh, and one final thing, club locks are a waste of time. Get an imobiliser AND alarm, preferably one that is monitored.
getting an alarm put in your car is only common sense really
and like everyone else has said, everything you will need to know about r34 gtt is on the site, just look it up
Before you get the car factor in money for quarantine holding fees ($25 per day - can take weeks or months), decontamination fees, tow truck costs from quarantine to your compliance workshop (very expensive) etc etc
After you get the car factor in money aside for alarm, insurance, tune up and maintenance aswell.
Edited by HotPlates
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
