Hey guys, Been having this problem for about a month now.. Got an R33 GTS-t with a GCG highflow and all supporting mods including injectors, z32 afm etc..
Had the car tuned about a month ago and couldn't boost the car over 14psi without the AFM spiking from roughly 4.5V to 5V and making the car basically cut off. This cut happens at around 5000rpm at boost levels from 15 - 18psi. The car suddenly just dies and drops about 1500rpm, and looking at the data logging on the E-manage the AFM voltage spikes up to 5v.
I thought this was due to a dodgy AFM so i sent it off and got it replaced under warranty. The new AFM is now on the car and its back on the dyno at the moment doing the exact same thing.
All boost cuts have been disabled on the E-manage, and tried changing the AFM values to read 4V continuously. One thing i'm thinking it could be is the stock computer cutting ignition due to excessive knock levels? Not too sure but i think the stock ECU has a knock cut built into it, which the E-manage won't over-ride? Any suggestions would be appreciated as the car is still at the tuners so we can try everything on Monday. Cheers, Shane.
https://www.sau.com.au/forums/topic/175762-cant-boost-over-14psi-on-e-manage/
You have pushed the AFM values to Boost cut.On your Air flow map have you gone + or -? You may have to Up the Fuel pressure and come back on the AFM map making the factory ECU see a lower voltage then use Ign and fuel maps to fine tune.
Or better still go for an aftermarket ECU.
The standard ECU is seeing too rapid a change in AFM voltages, you need to be more careful in your tuning of the EManage. During boost build you will have to compromise on the A/F ratios if you are opnly tuning via AFM voltage. This is not unusual, don't feel dissadvantaged, it's the same with all AFM voltage benders. I assume you will be tuning via the EManage control of the injectors after you cure this problem.
:thumbsup: cheers :P
sounds like what mines doing only mine is set on 12psi
no doubt it may be maxing my standard AFM and causing this cutting out at high revs
I thought my tuner may have been able to work around this little problem but he couldnt
its driving me mad at the moment
damn these auto GTT's wish there was an ECU that was as hassle free as the Power FC
yeah, we got it all working good on the dyno running 18psi. But on the road when loading the motor in 3rd or 4th up a hill it still cuts out. Gonna have to leave it like this for a while as got no more money to spend on it.
Another problem I'm having is at low revs and low Throttle % the injectors spike up to 99% duty for about a millisecond, can do it maybe 3 - 7 time in a row, This is causing the car to stutter and pop when cruising along and back fire when rolling to a stop.
In hindsight i really should have just gone for a stand alone, but hey, what can ya do.
That happens when you don't use a high enough ramp rate on the dyno.
Tuner's warranty?
I have heard of that before, it may be an EManage bug. But you should check the plus wiring anyway, just in case.
Unfortunately not much choice for autos.
:rant: cheers :(
if it was an r33 i would say search the net for a remapped ecu. that will not have rich and retard anymore so you can just tune it like a stand alone.
is it the emanage blue or ultimate? if it is the ultimate you could try getting the map sensor for the emanage and disconnecting the afm.
i was under the impression that as the emanages are piggybacks, you cannot remove the afm by using a map sensor. the map sensor just allows you map beyond the AFM's max readings
No, we've got the double whammy of AFM voltage cut, and the annoying boost sensor on the firewall that shits at 4.8v...best way around is a Z32 + FCD or bleed valve on the sensor.
you can remove the afm. you datalog the voltages of the afm and then use the airflow output map rather than the airflow adjustment map, then just adjust your fuel and timing in their individual adjustment maps.
yeah it looks like you need to set your boost cut more carefully, is it the blue version? if it is the ultimate do NOT make any fule mixture adjustments in the AIR FLOW MAP use the INJECTOR MAP ONLY. With the blue it is best to only subtract in the afm table and do the additional in the injector map.
Thanks for the input guys, But i've decided to sell it and have allready brought a PowerFC to take its place. I'm sure the unit is capable but i want to use an ECU that my tuner is more familiar with and just generally more information on. Anyone want to buy an E-manage Ultimate and harness for $550? Cheers, Shane,
WTF?? it was an ultimate and they could not sort it???? maybe look for another tuner.... the ultimate will do that setup a piece of piss.
what is the board code? (inside on the board, bottom right corner near loom plug) if it is a (E) i will buy it, i have a 33 to do on fri so it will save me pin swapping :P
Yeah it has an (E) down the bottom.
Over the past month my car has been in and out of the workshop, i spent all up about $1000 for 2 tunes. The first was at 14psi due to him not being able to overcome the boost cut, thought it was a faulty afm so i got it swapped for a new one.
Back in the shop for a second tune with higher boost, still doing the cut. He finally works a way around the cut and tunes it to 18-19psi, ok all good. I take it out for a drive, and the car stutters like crazy on light throttle, and is still hitting the cut when loading in 3rd or 4th up a hill.
So i go back again, they take the car for a drive, come back and say, hmmm we cant fix your car. they show me the data log of the injectors spiking to 99% at low throttle, and didn't mention the cut.
This Saturday i went for a drive with a mate, and it hit the cut a number of times and was stuttering and backfiring. i then thought to myself... f**k it, Im pulling it out and getting a pfc.
well thats the story, the E-manage is yours for $550 if you want it. Cheers, shane.
no worries, i will take it. where are you located? can you pm workshop to me. i will keep it confidential. i just need a list of confident ultimate tuners and a list that could do with some training. I am currentley looking at bringing the TRUST engineers over for a training workshop much like the MOTEC ones. I am overwhelmed by the enquireies atm and cannot do my own work due to the amount of emanage enquiries. emanage sales in aus have quadrupled in the past month and ive been left holding the tech support bag.....
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
