My 1989 R32 is up for sale atm,
Located in Jimboomba, QLD
serviced every 5000 or earlier.
15X,XXX klms
Reason for selling... I have a mental problem in that i don't want it anymore, car is running in perfect shape, slight panel damage from QR (turn 6). I need to money to pay stuff off, it needs to go before i move house.
I am the only owner of this car, since it was imported. Currently in the process of fixing the damage and putting the kit on, as well as a few other items.
- Chip and tune by Dr Drift
- 220HP on 10-13psi recent dyno (have sheet)
- gtr rims x 6 to go with 4 newer tyres.
- fmic
- fuel pump
- Apexi N1 Street coilovers
- KMAC front reat heavy duty sway bars
- Recent tyres
- have rear camber arms and HICAS bar (not installed currently)
- pod filter
- manual
- blitz boost gauge
- EBC Gizzmo controller (not installed)
- full 3" stainless steel cat back, dump pipe is 3" but only mild steel.
- twin outlet muffler
- front and rear strut braces
- alpine stereo
- have m spec kit in shed to go with
- recently replaced coil packs
- have Dr Drift engine cover to go with
- momo steering wheel
- isotta gear nob
- spare tyres to go with
- camber pins up front (set at neg 2)
- Viper pager remote lock, with remote start.
- Spare indicators and some Cefiro turning lights to sell with.
- extra front re-enforcement to sell with as well.
- Heavy duty clutch
- Slotted front rotors with heavy duty pads.
11 months rego.
will sell registered.
$10,500 neg
PRICE DROP!!!
TRADES WELCOME!!!
P.S. May sell 57IGG plates with extra $500
PM WITH OFFER, and questions.
or contact on 0403912509
---pics up soon---
Edited by Oblivion
https://www.sau.com.au/forums/topic/175780-r32-gts-t-4-sale-2-door-urgent-sale/
looks pretty sweet...so is it NA atm??
lol
I'm sorry!
nah buddy its gts-t rb20det......i wouldnt be getting that power from an NA rb20de.
Hey looks great But I can not see if there is some damage or not Plus the pics are at night and from a desent distance .
Can we please get somes pics of the car closer than 50m away and in some desent light .10.5k to spend on a car that you can not see does not sell .
Sorry man but every car I look at for sale is in the dark
yeah i will bud i havent been around home for the last week, so i will get some pics on the weekend.
if you are really interested you can come and look at it, can meet you somewhere. I dont expect people to buy it off the photos. But yes i will get more photos. The damage will end up being repaired if the sale doesnt go ahead for a while.
any pics yet with the kit on or of the damage?
im very interested and have cash ready to go straight away. need somemore pics and then i will come and hava look!
cheers
PM me back when ready!! thanks
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
