Hey guys I got a dyno run on saturday and my AFR is dangerously lean.. I'll try scan the graph and post it up.
But to fix this I will need a new fuel pump correct? I was recommended the the bosch 044 by Hyperdrive but then I've had someone tell me that its the wrong one for the R33 and I need the 040? I'm sure Hyperdrive know what they're talkin about though..
So any advice would be sweet as!
https://www.sau.com.au/forums/topic/175796-dyno-reads-dangerously-lean/
  • Replies 51
Hey man, I was in this position about a year ago, pretty stock R33, Leaning out. . .
Ended up getting an 044 through HyperdriveMS. . . They fit with a bit of modding and will pump right down to the bottom of the tank no probs. . . Just sounds like your boot is full of bees.
Be sure to check your AFM is not dirty, especially if you run an oiled pod. as this will stop the AFM from reading all the airflow and the ECU will be leaning out.
if you get one through the traders on here they are pretty cheap now i think!
good luck
I had the same as you when I had my 100K service done and was told that I needed a new fuel pump. I got a quote of about $1000 for a stock and $1200 for a NISMO version.
If you don't mind getting it online you can go to Greenline http://www.greenline.jp/ and get a NISMO from Japan.
Cost me $430 delivered to my door ex Japan and took less than a week to get here.
Edited by Hotrod
The Bosch 040 is an intank (044 External) and I fitted one in my GTS4 because of similar problem but turned out to be the std small Fuel Filter was clogged so bad I could not even blow thru it when taken out.
Replaced it with a much larger and highflow unit from a volvo truck or something.. it was much better just harder to mount but used a 3' clamp around it and bolted to std location OK.
I got an 044 for $214.50 delivered off ebay, pretty sure there is a trader on here that does them for about the same price. Was going to just install the 044 for peace of mind but am holding off till I get a surge tank and a Bosch 910 (910 to draw through the intank pump and feed the surge tank then the 044 to the engine).
Bosch here too - 040, less than 200bux, oh and DIY install. You'll just need a few hose clams and pliers :rant:
You can make a day of it, getting high in your boot with the fumes. I recommend it to anyone.
Oh, and run down the fuel till the light comes on before you start fishing around in there - soaking your arm in petrol will guarantee to cause "interesting dreams" when you fall asleep next to it.
Ok well I'm certainly not spending a grand on a fuel pump... should have checked the AFM and stuff when I was at Hyperdrive :rant:
Well I'll book it in for an 040 or something and while that's taken out we'll check the 'fuel filter' and see if it's not clogged up or something. Is there anything else that might cause the problem?
And will the car be running rich after a bigger fuel pump is installed?
i agree with going for the nismo pump, includes everything for a direct swap, not just that pump that needs moding like bosch pumps,
autoworx do them for $450 less 5% for members and they dont sound as noisy as the bosch pumps
but that just my opinion :thumbsup:
sam
?? i got my RB20det done at hyper on sat too with the same probs!!! wtf?? but they said the 040 would suit me!? well at least i now know what to look for!
was also told (by others) the Walbro is just as good as the bosch but not as noisy or costly....... ta guys!
(what time were you there??)
Edited by dodgsun
Lol true... I'm going to just take it easy and stay off the boost untill I can get a 2nd dyno somewhere else to compare.
I was there around 11am btw.
Hey guys Im certainly no expert on this stuff but just to add a bit more:
dodgsun - The reason they said 040 suits you is the style of inlets on the pumps, r32s have a conventional flat bottom fuel tank and have no worries with the mesh bottom on the 040, whereas the R33 tank bottom is not flat and they need a threaded bottom to accept the standard pickup tube and filter sock. Hence 044. . .
The Walbro pumps have been tested and shown to be no good at higher power because they lack the flow at high pressure needed for rising rate regulators and high boost.
Bosch are noisy but you can only hear it at idle with the stereo off or outside the car, no big deal IMHO. If you rubber mounted it it would be quiter Im sure.
SKY RYAN - changing pumps will not effect the mixture because the FPR sets the pressure not the pump, so it will keep the same pressure with more flow available. . .
Why don't you change your fuel filter as well anyways just to eliminate the possiblilty?
What a novel!!
Later
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
