Hey guys and girls,
Im currently in the market for a R34 coupe GT-T, for some reason i have found the yellow ones really appealing but unfortunately the few yellow ones i have found have been sold when i have rung up, and the other colour i was contemplating was the white, do you think that the white in the r34 is just meh or is it just me?
Cheers in Advance
Lam
https://www.sau.com.au/forums/topic/175801-r34-skylines/
Hey guys and girls,
Cheers in Advance
Lam
Hey Lam,
I think the white is a bit plain on the 34 the 33 in white looks okay i like my silver is nice ???
i think the black looks good! good luck. :rant:
https://www.sau.com.au/forums/topic/175801-r34-skylines/#findComment-3219708
Hey Lam,
yea i dont mind the silver but if it starts to fade silver looks yuk lol no offence, i find that problem with most silver cars
Lam
https://www.sau.com.au/forums/topic/175801-r34-skylines/#findComment-3219734
Lam
Put a good quality wax on and you wont have any problems... my R33 is silver and 10 years old today!
Still looks friggen horn
https://www.sau.com.au/forums/topic/175801-r34-skylines/#findComment-3219816
lol im about to step on some toes when I say and I apologies in advance. In my opinion, the ONLY kit that looks nice on an R34 GTt is the "other" Nismo kit, no not the one that everyone else has with the awkward looking mesh grill and the out of proportion rear bar. Its the one that was seen on Jspec a while ago, the silver 4 door Gtt with the very nice nismo bar, skirt and wing, everything about that kit seems to flow well with the Gtt's squarish design. Everything else seem to ruin cohesion. Having said that, the stock Gtt kit is pretty enough as it is.
https://www.sau.com.au/forums/topic/175801-r34-skylines/#findComment-3220826
I vote .. Yellow or bayside blue :rolleyes::D :D
Black is sexi ive got it .. Real hot when waxed like said above reflects everything and looks bad
\White looks really good with the Cwest kit or better with the impul kit with carbon bonnet or something really nice :)
Edited by DECIM8
https://www.sau.com.au/forums/topic/175801-r34-skylines/#findComment-3221323
Lam
Silver can't fade, it's a clear over base colour. only solids colours will fade, yellows and reds. When Iwas looking for an R34 I looked at plenty of red and yellow ones and they where all different shades of red and yellow. I bought a silver one.
https://www.sau.com.au/forums/topic/175801-r34-skylines/#findComment-3221377
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
    • But I think you missed mine.. there is also nothing about the 98 spec that supports your claim..  according to the fuel standards, it can be identical to 95, just very slightly higher octane number. But the ulp vs pulp fuel regulations go show 95 (or 98), is not just 91 with some additives. any claim of ‘refined by the better refineries’ or ‘higher quality fuel’ is just hearsay.  I have never seen anything to back up such claims other than ‘my mate used to work for a fuel station’, or ‘drove a fuel delivery truck’, or ‘my mechanic says’.. the actual energy densities do slightly vary between the 3 grades of fuel, but the difference is very minor. That said, I am very happy to be proven wrong if anyone has some hard evidence..
