Hey guys my name is Craig :rant: .
I'm building the RB30dohc
Was wondering what inlet plenum would be best suited 4 this setup other then goin custom ?
Even turb setup, injectors manifold etc pls
96 R33 RB25 head.
Edited by HR31DRFT
https://www.sau.com.au/forums/topic/175812-my-rb30dohc-build/
You dont say which "DOHC" ?
Easiest would be to go with the orig std setup, but as someone who has built a custom Intake plenum I would say it may not be worth the expense for the gain in performance.
I was never able to quantify the results from mine unfortunately as I fitted it with many other mods at the same time, but I dont think it made much diference except in looks and presentation.
Though it did enhance the FMIC fitting with no unesessary longer I/C pipes etc.
Definitely look at a R26 head and its std plenum.
Rb25 head for ~$1000 + ~$700-900 for a decent plenum.
That 2k can go a long way in buying a good rb26dett head and its std plenum and better factory cams.
Got this 25de head 4 $400
Was gona go 26 but found it hard 2 get complete. Covers etc this stuff can be a bitch 2 get in parts.
I dont mind goin the greddy plenum, 10k has been put aside 4 the engine build, already have block + head, rods, N1 water + oil pump.
N still have 10k hehe, i kind of like keeping 10k in my bank 4 as long as i can :rant:
I was gonna go Borneo setup, but alot of custom work what will be a headf*k.
I only want around 300-350 atw but 4 a while :rant:
As turboX said which head are you using?? RB25, 20, 26?
turboX your plenum looks pretty intersting any links to the build??
Just follow the link on my sig below and go to my website listed at the bottom -there's about three pages on it.
now somoene please correct me if im wrong..
By using a DE head.. you will have NA compression.. So.. about 10:1.
Because your going turbo.. you will have an turbo engine with a 10:1 comp ratio.. so.. you wont be able top push alot of boost though it.. engine longitivity will be greatly sacraficed.. and chances are.. your going to blow your head (hahaha)
Does the engine get its comp ratio via the head or the pistons/cylinders?
just a passing thought.. :dry:
Car is fully decked out in suspension love.
Kaaz 2way hehe fun times.
Its actually 300-350 hp not kw
Car is awesome now, dont need anymore power from the rb20 but i want 2 build a engine.
RB30dohc POWER
This bitch is gonna be sick.
Lumpy is building the engine, i'll leave that up 2 him.
Compresion ratio's will be adjusted 4 optimum performance, but like i said thats 4 the gurus...
I dont like talkin about stuff i dont have a full quid on.
Nice answere.. should tell that to the people that like to talk shit..
Keep us updated!..
be fantastic to see how she runs!..
Good luck and keep the details comming!
NA head is fine; it won't affect comp ratio as that is achieved by the domed pistons the N/A motor uses.
Drop the head on a N/A RB30E bottom end and you will end up with around the usual 8.2-8.3:1 comp ratio.
The N/A bottom end with the SOHC head achieves a 9:1 comp ratio; the DOHC lowers the comp from 9:1 to 8.2-8.3:1 because its combustion chamber is larger.
Yeh not rushing anything !!!
Building the engine in 2 parts...
Bottom 1st
All little bits like crank collar etc are goin 2 be used.
Using Mahle racing pistons
Head 2nd
Porting polishing work but really not much is required but doing anyway cuz i'm there u no.
Comp ratio's will be worked out so they are exact for fuel i'm using and what i'm doing with it.
But yeh havnt looked into it yet, just read and fully undestood the RB30dohc build guide.
As all says, a really good builder is assy the engine so i'm not gonna loose sleep over ratio's
I will blow the project out a couple of months if it takes, 2 get things exact or as close as poss.
No dead lines
Then paint :dry: lol
Thanks guys i appreciate the feedback
P.s i work at Coventry's so alot of gear is from here cutting costs big time.
U gotta cut at least 1 corner hey.
Bottom 1st
Head 2nd
No dead lines
Then paint :rolleyes: lol
a light polish is the way to go, ive seen more gains from mates who have done a mild polish than a major polish when aiming for lower hp.
i got most of my rebuild parts from coventry for my rebuild through my mate when he used to work there. it was probably the cheapest rebuild in history lol (just a std rebuld). i got pretty much everything but the rings from them.
goodluck with the build mate.
Thanks dude,
Head is gettin a light polish, we all need a polish every now n then :rolleyes:
Will be a great package.
Will keep ya's posted.
Goin 26 head now thanks Richard :D
POWER TIME :D
Edited by HR31DRFT
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
