Hey guys,
This group buy is now finished. Thanks to Amec for the great product, and also thanks to Dez for putting in the effort to get this GB through. Also thanks to all the buyers that paid up. I don't think Amec will be making anymore of the black kits (unless someone does another group buy and gets another 20 buyers) so we're all 1 of 20 with this kit.
Please follow these instructions to leave feedback for myself, dez, and Amec for the product itself.
leave feedback for me here : http://www.skylinesaustralia.com/forums/in...r&mid=14874
leave feedback for dez (keeping in mind he is responsible for the majority of the work involved with this group buy) here: http://www.skylinesaustralia.com/forums/in...=22515&la=0
and also for Amec (feedback on the product itself) here : http://www.skylinesaustralia.com/forums/in...r&mid=27224
Here's some pics of the kit installed in dez's car:
In-
1-Dezz - Paid
2-Jar - Paid
3-Justin911 - Paid
4-tek_01 - Paid
5-BLACKZILLA - Paid
6-immortal^ - Paid
7-R33-GTS - Paid
8-Jaron - Paid
9-drzexa- Paid
10-madaz- Paid
11-Zilch- Paid
12-vidak- Paid
13-Xizor - Paid
14-jeffworld2 - Paid
15-johnblack33- Paid
16-R334door(s2)- Paid
17-M E S O G L E A - Paid
18-EVL-R33 - Paid
19-SevenAngryPenguins - Paid
20-josh*** - Paid
Cheers :rant:
  • Replies 190
these kits are great, i have a white kit and love it, although initialy i was after a black, but was unavailable at the time. The instalation is easy and the kit is spot on, VERY profesional, not a cheep imitation, proper plastic backed guage inserts.
GO for it guys.
GO for it guys.
Thanks for that mate...good to hear that someone with the kit loves it....you should still grab a black one though :rant:
List updated, 6 people are in for a kit, and a few of those people might be buying a few extra kits to secure the minimum of 20 kits if they need to...get in on it people!
count me in as a maybe, by the end of august i should have some cash spare to get one
I've put ya on the list, but we're hoping to have enough people way before the end of august...don't stress though coz like I said a few of us will buy a few sets to make up the last few numbers if we need to, and we'll just put em up for sale for the same price
these look nice`and are cheaper hey... in your pic above in the night version, is it possbile to get that kind of night look with the white kits as well?. .. what bulb is that you used in the pix above?. thanx
any for a r32 my mate is after 1???
Amec never got around to making them as far as I know...this buy is for R33's, so ask Amec I guess...
ill take one.
added ya to the list :dry:
the night pic above is the white kit...they'll both look pretty much exactly the same at night because you won't see the color of the faces, just the light coming from behind....thats not my car but pretty sure they're normal white globes...not even LED i dont think... but get a set of these black ones man, they look way better :w00t:
thanx for that.. black is beta hey.. i like the psi change.. way beta.. looks like ill have to cheack my money :dry: ... and toss up white or black.. my other gauges are white, so the same color would maby match.. ill get back to you for which one :w00t:
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
