  • Replies 190
They look great .... yeah put me down for one thanks, Pfft $100.00 bucks its nothing right ?
Spot on mate, these aren't my product but I honestly think $100 is a bargain!
13 people in now guys, A few more and I rekin we'll be set!!! :sorcerer: :sorcerer:
They look pritty cool so count me in for a black set pm-me with details etc. :)
added you to the list dude....we're looking good for this to go ahead, so I'll send out PM's soon with account details and we'll get this show on the road!!! :)
cool thanks mate lets get this show on the road been hanging out 4 ages 4 a 300km/h black faced kit for ages well done now lets hope you fill the quote for Amec :)
hey guys i might be in but first i just wanted to know when installing these coz the stock dash goes or 180 do you have to get the dash re calibrated???
if not then i will confirm by monday as i maybe getting my skyline this weekend YAY
Yes it needs to be recalibrated, but its not a difficult process and you can do it yourself if you know how to use a soldering iron...the kits come with instructions, and you pretty much just solder some points together on the rear of your cluster which re calibrates it to the 300km/h cluster which is in some GTR's
Let me know if you want to be put on the list :dry:
yes i do! but my car isn't a turbo?
There's another guy on the list with a GTS, Amec (the trader that makes these) has said he's happy for non turbo owners to buy a kit, try install and calibrate it, and if it doesn't work you just send the kit back to him and he'll refund your money
let me know if you wanna jump on the list :dry:
hmmm ok white or black?
my cars black with a carbon fiber dash, white rims, white could look good.
if its not write for my car cause its not a turbo may look silly
Edited by Ally
Black is where its at :dry:
Let me know if you want to be put on the list :rant:
thanks for that man really helpful.
ill have to confirm 100% on monday coz it all depands on weather i get this car or not. i most likely will but ye ill confirm on monday.
thanks
Ash
I AM IN FOR A BLACK ONE !!!
Send me the details and I'll forward the payment
good man...we're up to 16 now so i'll be sending PM's with the payment details shortly :)
I've sent PM's to everyone on the list above with payment details. Please make the payment as soon as you can so that we don't have to wait any longer than necessary :P
Anyone else wanting to get in on the group buy, its not too late of course...I'll send you PM's with the payment details as you join the list
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
