  • Replies 190
This group buy is now closed. All kits are sold and paid for.
Amec will post all kits mid next week, so we should have them by next weekend.
Thanks to all those who have participated...you're 1 of 20 people that will have a black Amec 300km/h speedo :D
Cool well done to jar and amec for taking the time and effort to get this group buy hapening well done :D
Kits will be sent out by Amec tomorrow, so unfortunately that might mean early next week arrival and not before this weekend....Unfortunate but at least they're very close to being at your doors!
aust post aren't that bad most metro area's should be next day delivery on standard rate ie: not express
thanks for keeping us posted
will it come with detailed instructions on how to get the needles off because i saw that thread with the how to get cluster out but there wasn't really detailed with pictures on how to remove and what to be careful with on the needles
i doubt there will be instructions dude..
Amec has just informed me that he sent out the kits tonight, so with any luck you'll have them friday, then you can spend the weekend installing them :whistling:
yay *JaR* received the speedo kit today they look sweet dude cant wait till the weekend to fit it
10/10 blokes well done
Yeah +1 Cheers Amec and ESPECIALLY *JaR* because without JaR we would be paying full price
now do we give both a trader rating? im thinking yes?
good to see you're recieving your kits...they do look great :)
As far as trader rating feedback goes, it'd be awesome if everyone who participated could do the following
leave feedback for me here : http://www.skylinesaustralia.com/forums/in...r&mid=14874
leave feedback for dez (keeping in mind he is responsible for the majority of the work involved with this group buy) here: http://www.skylinesaustralia.com/forums/in...=22515&la=0
and also for Amec (feedback on the product itself) here : http://www.skylinesaustralia.com/forums/in...r&mid=27224
If everyone could do that it would be good that the people involved were recognised for their efforts in the GB :yes:
Also everyone post up pics as you all get your kits installed so everyone else can see what they missed out on!
THIS GB IS NOW OFFICIALLY CLOSED :sorcerer:
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
