just a quick question, wondering wat sort of power a stock gtr gearbox (roughly 100,000kms) is capable of holding before you start pushing it to its limit??
i know there are a few ppl that will say, depends wat clutch you got? and depends how you change gears?
but im just looking for a rough idea.
thank you.
https://www.sau.com.au/forums/topic/175859-gtr-boxes/
yeah ok thanks. i was just crusing around the forums and found a lil info on some boxes and stuff. just so you have more of an idea, im running a t51r, 2way lsd and a giken triple plate. i didnt really wanna push it past 400rwkw, but am starting to think, why such a turbo if im not gonna open it up, so im now trying to work out wat box to run. a friend of mine has a trust 6 speed straight cut (quiaf or watever) for sale, but am concerned about rumours that i need to rebuild it every 5000km??? this is somthing that i am not keen on, should i be concerned?
the car will be mainly street driven on special occasions, but will hopefuly make a few track meets and drag events, if all holds together. :thumbsup:
https://www.sau.com.au/forums/topic/175859-gtr-boxes/#findComment-3220774
Your combo is a recipe for lunched boxes, haha no disrespect just as you are obviously aware the standard item isnt going to be up to that turbo, clutch or diff!!!
PPG from personal experience are awesome.
OS are good and economical so make a good option and would suit your purpose.
Trust had no personal experience so I wont comment on hear say!!
Edited by Fitzpatrick Speed Works
https://www.sau.com.au/forums/topic/175859-gtr-boxes/#findComment-3220902
Depending on how you change and what clutch you have can factor in how long your box will last, power shouldnt matter unless your going over 600rwhp and wanting to blast gears
I destroyed box1 with 390rwhp with exedy twin plate shifting to fast and dropping the clutch
I destroyed box2 with morehp with the same clutch shortly after the drags, first started the noises from box then bang when i shifted
The third box has being fine and lastest for ages because iv treated it nice and shifted normal ..
once there into gear there fine
treat it with love and your fine
https://www.sau.com.au/forums/topic/175859-gtr-boxes/#findComment-3239053
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
