Here is the WHOLE story.
Purchased a Skyline R34 GTT from E&M Unique Motors 3 weeks ago *** Not flaming them so i don't see why i can't mention the dealership ***
I had it inspected by Stateroads before i took delivery and i also went over the vehicle and had it for a test drive.
1st issue - Took it for a dyno run at CRD. Was pulling 110kw@tw. Was an issue with the boost controller not being set right so they fixed this and now it's running 200.5kw@tw on 12psi.
2nd issue - Clutch release bearing was stuffed. They took the car in and replaced the clutch and machined the flywheel free of charge. Although i had to pay for a hire car...
3rd issue - Went to Advan today and got the compression test performed.
Cylinder 1 - 175
Cylinder 2 - 170
Cylinder 3 - 175
Cylinder 4 - 170
Cylinder 5 - 75 <--- WTF!!!
Cylinder 6 - 170
The guys at Advan said that it could be something in there like dust etc...unlikely but it could.
Also said that it could be the ring not sealing properly or the piston has worn out.
Advised me to drive it off boost and to get it checked out again at E&M.
Called E&M and advised them of the issue.
The first thing they asked was "is it idling rough? Is it misfiring?"
Advised them that it wasn't and they said "no need to bring it in".
I insisted on taking it in and he told me to call next Monday to book it in.
So was the guy trying to not do the test because he owes me new pistons or a new engine?
Or is he right? ie. no misfiring and no rough idle = engine ok?
POST EDITED
Edited by Fujiwara
https://www.sau.com.au/forums/topic/175863-got-a-compression-test-done-today/
So it has warranty?
If thats the case definitely bring it in. Say you've had it compression tested and cylinder 5 has shown up as having issues.
Regardless if its running smooth or not missing if a cylinder is down on compression it has issues and should be sorted under warranty asap.
Hi
Overall it does not sound right, check out the warranty conditions. They may only have to cover you for 1 month and thats why they are stalling. Check with governing departments or the car yards warranty company.
good luck
Yep drop it in ASAP and have them sign a statement stating when the car has been dropped off and what the problem with it is.
Attach a letter from Advan stating the compression test results and say to the workshop it is to be fixed under warranty.
Don't let them stall and push you around; I've been there and done that and learnt the hardway. :dry:
If they state they can't get to it until x date still leave the car there as if that date is after the warranty has ran out your out of luck.
If you think the company is deliberately stalling you to avoid having to pay for any repairs then write a letter to them stating what the issue is, where it was found and by whom. Then post this as registered mail IMMEDIATELY. This then becomes their first formal notification and they have to sign for it to acknowledge they they received the correspondence. Do not delay doing this as it may be crucial in the worst case scenario where you end up ahving to take them to court. I'm not trying to scare you but it takes very little effort on your behalf, costs stuff all, and can save you heaps of $$$$ in the future. The one thing that I've learnt about our legal system is if it doesn't exist on paper then it simply doesn't exist.
thats odd. i thought you would have noticed if the comp was downs that low on 1.
And I wouldn't have thought you'd get 200rwkw out of it at 12psi.
Pays to get it checked out though.
Maybe repeat the test..at the place that are going to do the warranty. Make sure you are there and check they reset the gauge before they put it on the faulty cylinder
Isnt 170-175 too high for a turbo engine? Shouldn't it be around 150?
Are you sure u didnt buy a non turbo?
Definitely bought a turbo. Has the turbo rush. Guys at Advan didn't say anything about being too high. They just said it's heaps healthy.
Also, fastened the VIN and it is a turbo
could it be a screwd gasket??
Can someone else comment on this?
And can a head gasket cause just one cylinder to be down by 100psi?
yeah. is it a 10year old car?
yeap...10yr old car.
it wouldnt hurt to do a leak down test while you are at it, might give you a little better insite?
was performed when i had the prepurchase inspection.
No issues. Pity they didn't perform a compression test..... :thumbsup:
yeah. make it formal. or simply say yes it is f**ked and running like shit.
Definitely sending an email today (better to track with email)
unusual. the turbo will pop before the motor
How so? And how will i know IF my turbo is about to go kaboom?
So 100psi down on one cylinder would make it impossible for me to get 200kw at the rears?
The guys at Advan say that it COULD be a one off issue. They retried the same cylinder about 4 times though. They said once i start driving around, any "dust" in there could go away and the rings could seal properly IF it was that issue.
Can anyone else comment?
I have the dyno graphs here...excuse the crap quality...taken with my phone
Edited by Fujiwara
If you had a leak down test done pre purchase and it was good then you may want to read up on what it is you tested before jumping the gun based on a compression test result.
You will not make 200rwkw on 12psi if one cylinder is bleeding off pressure.
I suggest 3 possibilities, 1) it's a dud compression test, 2) Your initial leak down test was dodgy, 3) you've broken the car between your initial leak down test and the later compression test.
If you take the car back to E&M to be checked and it shows all good, you will be charged for it. If it shows up bad, then make sure you are familiar with your warranty conditions because you had it independently tested, and it was good when it left the lot. You've played with it in the mean time. I think you will lose if it goes before a judge.
Not trying to be harsh, but seriously, find out what you tested pre purchase before going any further.
Im with Dave. Now that you say you had a leakdown prior to purchase and all was good there's not really much you can do.
Have another comp test done; chances are the test was a bit bogus. How many times was each cylinder tested, should be seperately tested at least twice if there's any funky readings.
If it has lost compression all of a sudden it would indicate detonation and smashed ring lands in that cylinder.
It is making 200rwkw on the stock ecu with 12psi so really it is quite highly strung. That small SMIC would heat soak fairly quickly after a hard run, keep your boot in to it and it will rattle its head off. The knock sensors only protect the motor around peak torque, high rpm the ecu ignores it.
also if it was that low in compression in 1 cylinder you would be using a touch of oil and it would blow a bit of smoke when you got into it a bit. get someone to follow you and then give it a good bootful through first and second. if there is no sign of smoke it make be a dodgy test. if it does blow white smoke then the test is correct.
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
