Hey guys ..
I have r33 series 2 model rb25det .. 3inch exh cat back, triple core radiator, bov, apexi power in take filter is only mods atm, have a fmic to go on ..
anyway my question is, i purchased boost controller, upped the boost 2 pound and its pinging, even on stock boost sometimes its pinging around 5-6g in second .. i got the timing and everything adjusted, but still the same.
boost is coming on really smooth also, dont feel much force, also im getting 300km per tank, no matter how i drive, sometimes with long highway trips, any answers would be appreciated as its frustrating me.. easily should run 8-10psi without pinging
thanks..
https://www.sau.com.au/forums/topic/175882-pinging-problem/
Hey guys ..
thanks..
Are you sure its pinging and not missing, some ppl do get confused.
https://www.sau.com.au/forums/topic/175882-pinging-problem/#findComment-3220706
Pinging sounds like someone's shaking a can of rocks under your hood. Does it sound like that?
Could be your fuel pump dying, even though you don't get much economy and its running rich, it probably can't keep up under high load/heavy acceleration thus leaning out.
Edited by KeyMaker
https://www.sau.com.au/forums/topic/175882-pinging-problem/#findComment-3221033
well i wouldnt call it shaking a can under my hood, i back off soon as i hear it, and i do know what pinging is .........
as for the fuel pump i will try it mate, thanks
it is running extremely rich .. i just cant figure out why .. if i drive hard i get 290 - 300km.. if i grandma it, 290 - 300km ,, doesnt make a difference :thumbsup:
any other suggestions would be a great help :domokun:
https://www.sau.com.au/forums/topic/175882-pinging-problem/#findComment-3221068
Your bad economy would have something to do with your really rich AFR's. Stock ECU still? Could be various other things too making it rich.
It can still run rich when it's not under hard acceleration. But when you do give it a bit, the pump can't flow enough fuel to keep up with the air intake.
More air = more fuel.
Edited by KeyMaker
https://www.sau.com.au/forums/topic/175882-pinging-problem/#findComment-3221079
might be oxygen sensor. A stuffed O2 sensor would make it run rich, doesn't matter how you drive it.A car running lean doesn't make it ping. pinging is 99% of the time caused by too much timing. It might be a few different problems, but i think its pinging because of something to do with your timing. Maybe your CAS is stuffed...
https://www.sau.com.au/forums/topic/175882-pinging-problem/#findComment-3221236
a car running lean will make it ping. if it is running lean then the timing will be too advanced for that amount of fuel. and when it runs lean your cylinder temps increase which means there is more chance of pre-ignition. too much timing causes pinging in the same way that running lean does. if it is running rich then it won't ping as easy. it may be worth getting your base timing checked in case it is way out.
how many litres are you using to get 300kms? saying that you are getting 300km to a tank means nothing. if your guage is out and you may only be using 3/4 of a tank. i was getting a bit less than that out of my car and my afr's were 14.7 at cruise and around 12 below 5000rpm and then dropped to 11.5 by 7500, which isn't very rich. it was just the way i drove, and the fact that i did a lot of short trips on cold start enrichment, and drove spiritedly when it was warm.
https://www.sau.com.au/forums/topic/175882-pinging-problem/#findComment-3221369
very very unlikely though, to the point where to would be running way way too lean that theres no way he'd be able to drive it, it wouldn't be drivable. i'd even go to the point of saying fuel would be the very last reason a car would ping, theres other things that would make it ping before fuel would, like hotspots inside the cylinder, spark plugs too hot, or even shit fuel, but the most likely cause would be timing, any mechanic would look at this first and if thats not the problem they'd look at other possibilties, running lean can help in causing pinging but its doesn't cause it to happen by itself.
https://www.sau.com.au/forums/topic/175882-pinging-problem/#findComment-3221434
if you set your car up for 12.0 afr's and then run 13.0 afr's it will ping it's arse off. we put a new fuel pump into my mates r33 a few weeks back. before the pump went in it was running about 13.0 afr's and pinging it's arse off. put the new pump in and the afr's went down to mid 11's and there is absolutely no sign of pinging.
yes timing does play a major part in pinging, but so does the amount of fuel. hot spots in the cylinder, etc are cause by temps too high. running lean raises the temp.
https://www.sau.com.au/forums/topic/175882-pinging-problem/#findComment-3221449
what about injectors, dirty or half blocked maybe not spraying right and causing a hot spot. even coke build up causes hotspots.
again, running lean doesn't cause hotspots either, other things would do that before running lean does, and in this specific problem he ain't running lean its running rich. and thats what i'm replying to. I agree running lean does raise the temp but there other things to consider before saying its pinging because its running lean. My car was running very lean, in the mid 14's but it never pinged.
if the car was running that lean that it raises the temp that high for it to ping he would know something was wrong before hearing it ping, but he only got 2 problems, 1 running rich, and 2 pinging.
https://www.sau.com.au/forums/topic/175882-pinging-problem/#findComment-3221458
Just because its running rich in certain part of the map or on closed loop, it can still run lean in another part eg at WOT.
And I also take it that your saying that I can put a crappy fuel pump that can't keep up in my car and it won't ping even if everything like the timing, sparkies, injectors else is ok,? I'm talking about when it's under load/WOT not cruising.
Edited by KeyMaker
https://www.sau.com.au/forums/topic/175882-pinging-problem/#findComment-3221521
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
