Yeah, around ~1.41 was the time I recorded. It's very hard to drive without brakes, I'll be the first to tell anyone that. It's better that you backed off instead of trying to keep pushing like I did last time. Your brakes are still usable... :laugh:
Edited by salad
  • Replies 47
Posted Images
Running crusty old Yokohama A048Rs, they've gone rock hard and the rears have started to go a little blue, grip a little bit better than a street tyre, but they dont go greasy after a few hard laps like a street tyre would, in fact the tyres stay pretty constant over the 15min session.
Would love to put the highflow back on, but there is no part of it that is salvagable except the housings, and Bill has said it's not his fault. Not much I can do about it, so I'm out $600 for the turbo and $200 for the tune I dont need now :D. And now I've got GTR injectors in there that I dont need...
Tune and injectors will be handy later though, so yeah. We'll see anyway
Ideally, I wanna be out there with brand new RE55Ss, GOOD pads + slotted rotors and 220rwkw, should be a good time with all that :laugh:
Edited by salad
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
