i have a 1998 semiauto r34 gtt. with intercooler, airfilter, BOV .and i drive it normally.but it just can keep going for about 280 km with a full tank.
i use #98 petrol, and fill in about 48 liters to make it full when the indicator tells me there was few petrol. is the fuel tank of gtt 50L ? i just want know a normal situation of the gtt's fuel consumption thanks a lot.
Hey Dude I have a R34 GTT tiptronic auto Hybrid fmic, full exhaust from turb back,Greedy ebc, Safc2,BOV, POD, and my car gets 300 km to a full 50 lt tank it sucks what is wrong ????????????????? :thumbsup:
Edited by YPLAY4
its all in how u drive the car keep it off boost and u will do fine. i have a r32 gtst with fmic dump pipie full exhaust stock cat uped boost pod filter. and i get 450 to 500 normaly but when i give it some i get bout 300 to 350 and thats not even on empty.
GTT tank is 65L. If you used 48L to top up then you have approximately another 17L left. 280kms to 48L is still pretty rich. I just filled up my tank today with 47L after having done 360kms.
The usual culprits are O2 sensor, spark plugs, AFM...perhaps take it for a tune and service.
NISMO is right, the tank is about 65L. I'll normally get about 400kms region to a full tank. I don't run it till the lights come out though. Got a 3" turbo back, fmic, pod, ssqv, boost at 12psi, foot is a little heavy at times :nyaanyaa:. Really depends on how you drive.
changing the o2 sensor will help, changed mine and i went from 300km a tank to about 430km tank.
This sounds more like it. I have a s2 stagea (r34 engine, gearbox), which is quite a bit heavier than a skyine and on 48L my car will get over 400km around town. Its got 160awkw too so its not stock either.
My guess is that you should at least be getting more than 350km on this amount of fuel, modified or not. If its doing less than that, you need to either adjust your driving style or look for whats causing the problem - eg. check your O2 sensor. :D
A good free-flowing exhaust, SAFC or similar, and improved ignition timing will help your fuel economy as well, not to mention a bigger turbo (off boost while cruising). :D
As others have previously mentioned, the fuel capacity is 65L so try pumping it as much as possible. Reducing the use of boost should help acheive more k's. If not u better get it checked out.
my 2c worth
the following could be causing it too
Dirty air filter - causing the motor to work harder than it needs to , cause its not getting the airflow it needs
Slightly too thick oil - are you using the correct grade of oil in it ? I mistakingly used some stuff that was too thick in another car I had - and I did notice a drop in economy
change the o2 sensor as previously advised
have you ever had the car on a dyno? the dyno readout of AFR can definately tell you a LOT about what your motor is doing. I think if you were chasing the most kays per tank .. an after market ecu or a few add in mods like a SAFC and a SITC ( I think thats the one that controls engine timing )
if you got the above fitted . and spent some time and money on a dyno tune.. you would probably get more power and use less fuel. dont forget if a motor is running really really rich .. then its safe.. but .. its just pissing fuel out the tail pipe , leaning the mix to a leaner (yet still safe ) will yeild more power and less fuel consumption - but dont fall into the trap though of getting a bit more power and driving like a maniac - cause of course your goign to use more fuel
good luck matey!
if you can afford it run with a good fuel like BP ultimate 98 - just less chance of it pinging/detonating if you push it hard.
Oh and .. have a look around .. because you can find " equivalent " o2 sensors that are usually less expensive. To be honest I am not 100% certain if the equivalent o2 sensor will be " just as good" as a geniune one. But its worth a go.
Make sure you get some good crimp connectors to join it up , as my previous experience with this proved that the wires they use on o2 sensors are impossible to solder ( I think they are stainless? )
thanks everyone .now i think i catch the key point.
another question : which grade of petrol should the gtt fill? #98?
As this had been covered many many times, anything just 98 Octane will be just fine. Be it BP Ultimate, Caltex Vortex 98, Shell V-Power, V-power Racing, Mobil Synergy, they are all fine. Just a personal preference on which 'BRAND' one prefer.
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
