I am waiting to get to the end of our tank to see how the fuel consumption is going after my 1st service.
who knows a cleaner air filter and new oil and plugs etc could make a difference
I am really interested to hear of peoples opinions on wether or not the " equivalent " o2 sensors work as well as a genuine Nissan one. I dont really want to pay near on $250 for genuine
couldnt hurt hey?
oh and something else I noticed on the weekend.. when I was leafing thru my service manual
it actually says that the o2 sensor should be serviced/changed at 40 thousand and 80 thousand k
so .. I wonder how many imports have NEVER had it changed.
being that your not going to really notice it not working other than shitty fuel economy
If people are interested, i might just ring up and find the prices for OEM O2 sensors then.
i only fill up when the fuel light turns on...which that point i think theres only 10lt left.
so for the rest of the 55lt i only get around 280km but only boot it from time to time
no major mods but runnin really rich i reckon
For guys who are getting over 400+ km, I presume you are babying the car most of the time? I would be lucky to break into the 300km, guess that’s the down side when you drive your car once a fortnight.
Mind you, I do remember getting over 400+KM when the R34 was stock as a rock. The pod and exhaust threw the fuel figures out the window. Would love to see what happens once the turbo, cooler, injectors and pump gets done :())
Mind you, I do remember getting over 400+KM when the R34 was stock as a rock. The pod and exhaust threw the fuel figures out the window. Would love to see what happens once the turbo, cooler, injectors and pump gets done :D))
If it was me I wouldn't just be accepting this as normal.
Get your car dyno'd and check the Air Fuel Ratio graph. It should be somewhere around 11.5:1 at the lowest point. Any lower and its likely to be running too rich, which essentially means you're throwing fuel away, with no additional benefit.
If you dont have an SAFC or similar ecu to tune AFR's, then I'd suggest this be your next mod. It should cost you $400 all up for a 2nd hand one, including installation and tuning (depending on where u go). And while you're getting it dyno tuned, check your ignition timing at the same time.
Its all about getting your engine running as efficiently as possible, yet still safely. With a good tune you should be seeing improved fuel economy and it could pay itself off in 12 months or maybe earlier, depending on how often you drive. :)
I found with my car that even just an exhaust can push your AFR's down to 10 or even lower if you raise the boost. They run rich from the factory and adding more boost will likely make it add more fuel and run even richer. Even an exhaust can raise the boost level and end up using more fuel rather than less.
You should be able to easily achieve over 350-400km to a tank provided you dont drive around with your foot to the floor and dont ONLY do short trips (ie. with the engine running cold).
So to summarise, some things to do to lower fuel consumption are:
- get a free-flowing exhaust
- install a SAFC or similar ecu to tune AFR's.
- check ignition timing on a dyno
- use boost a little less (or not :( its what you bought the car for right?).
hope this helps. :)
    • 99.9% of them are viscous diffs. The 0.01% are helicals. They were only option-able in the series 2, as well. I have redline heavy shockproof in my helical. It seems... fine? I don't think anyone is ever going to know until something really breaks and at that point I'm not sure anyone will blame the oil. I just chose it because it's extremely heavy duty and my car will see not-road-legal duty for it. I've also had sadness with various diff oils in the past sweating out everywhere and/or other 'fun' things, with clutch diffs. Given you have a 1.5 way on the shelf, I'd not even bother with the diff in the car and just get to tinkering with it. I would spend the $90 on oil toward the labor of someone else putting the diff in if time poor even lol.
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
    • Throw between gears are so much that is getting annoying. I have pro short shifter on my mx5 and e36 and love it . Skyline is getting unbearable    would syncro issues and short shifter is no no? Anyone mind explaining a little on why before i buy cube
    • No. Well, some people "seem to use redline shockproof in the diff". Most do not. I would only contemplate it if you have badly worn CW&P gears. And no. No-one in their right mind has ever put ATF into a diff. Any normal diff/gear oil of the right viscosity will do. Whatever takes your fancy. Castrol, Nulon, Penrite, Redline MT range. Whatever. It's just gears. 75W-90 or 80W-90 is typical. I think that GL-5 is hard to avoid these days, although I think that a GL-4 is probably preferred, given the vintage of the equipment. At least Redline offer a number of GL-4 oils. If you have a clutch type LSD instead of the VLSD, then of course you need a proper LSD oil. Anything from any of the same names above. If you have a helical LSD, then it does not require LSD oil, and the recco is the same as for the VLSD. You don't want the LSD friction modifiers in the oil for a non-clutch type LSD if you can avoid it.
    • You may want to list it up for a little higher - This price is much lower than you may realize. Here you're pretty much selling to people who most likely already have these things on their own rigs. S chassis people eat this stuff up like you'd not believe.
