you drive an alfa romeo spider? cause if you do, i have no idea...
skylines, if you own one, theres a fuse box next to your right knee when your sitting in the drivers seat (there are also tongs and spare fuses there unless someone has used them) there is also fuses in the boot near the battery (33), and a box in the bonnet...
https://www.sau.com.au/forums/topic/175968-no-ac-fan/#findComment-3221523
why would i be asking on a skyline forum if i drove an alpha??
yes i do 'own' one.. i did look in the fuse box under the drivers dash.. but my japanese isnt that good so i thought instead of me having to put a meter across every fuse i would simply ask and see if anyone knew.. i didnt know about the fuses in the boot, but will check in there too. Yes it is a 33, but i thought all the fuse positions/locations would be fairly similar throughout each model.
thanks for your help :sleep:
https://www.sau.com.au/forums/topic/175968-no-ac-fan/#findComment-3221663
If you mean the Radiator fan doesnt come on when you turn the A/C on - thats normal!!!! It will only come on if the radiator water temp is past a certain temp via a thermo switch. Its similar to when A/C isnt selected on , the fan only operates by temp thermo switch. Hope that helps. You can check the fan operates by bridging the 2 wires in the connector thats just down the left side of the radiator (looking towards the rear of the car), that will bypass the thermo switch.
https://www.sau.com.au/forums/topic/175968-no-ac-fan/#findComment-3222063
Ă—
Ă—
