Hay guys!..
I hope this is the right section to post this in!
I have a 4dr GTS4 R32 and it feels kinda.. well.. FAT.
Question is.. What gains are to be made by stripping? And stripping what?
I noticed the bonnet is freaking heavy! Anyone know the weight? OR what the the weight of a Carbon FIber bonnet? How much am I saving?
That stupid front lip that slides down (what is the freaking point of it!?! Can you even put it down whilst drving? How?) How much weight do i save by ripping it out with the driving motor and going aftermarket front lip?
Aftermarket fiberglass front guards.. worth the weight saving?
Rear Seats? Weight?
Does anyone have drag/circuite times/weights of items or stripped and un stripped cars to compair?
If no one has any solid info.. I may do a write up.. Drag times while porky.. and after being anorexic. Kg. of each item etc. Would anyone be interested?
Cheers in advance..
Cris..
https://www.sau.com.au/forums/topic/176009-vehicular-diet/
think you save about 100kg by stripping out EVERYTHING, seats, aircon, carpet, fuzzy lining, sound deadeners, dash board, all plastic in the car etc etc
then you are left with a slightly lighter car which is rather unbearable to drive
all that for nothing..................$0!!!!!!
second approach is to spend $$$$ on carbon fibre bonnect, fenders, doors, bootlids, cf door trim, front bars, rear bars.........All up probably $10,000 worth of carbon fibre parts. Then take out all the windows and replace them with plastic.
This approach will kill your wallet in no time but makes the car so much lighter.
or you can combine the two by stripping it out AND replacing the outside panel only with CF, obnoxiouly loud, no creature comfrot but very very light.
https://www.sau.com.au/forums/topic/176009-vehicular-diet/#findComment-3221898
LOL!.. i was thinking more along the lines of:
CF Bonnet
FG Quarters
New bar
Take out the rear seat
Other random things I dont need..
I may do a write up about weight saving..
Although.. Id rather spend 10K on engine mods..
https://www.sau.com.au/forums/topic/176009-vehicular-diet/#findComment-3221904
optimistically, save around 15kg in bonnet, 10kg seats, 5kg for panels, maybe take out the HICAS for another 5kg-10mg diet, take out ABS for another 5kg
but then if you go get yourself some large shiny rims, that'll just add more weight. I'd go for CF bonnet, take out rear seats and lightweight wheels.
Take out ABS and HICAS if you can be stuffed.
https://www.sau.com.au/forums/topic/176009-vehicular-diet/#findComment-3221924
Umn, just wondering if you have completely changed your suspension and stiffened the chassis? because if you have stock 32 sus/shocks and lack of bracing then it's not the weight that's making it feel fat...
Address if you have not allready, them issues. ie- coilovers, struts, sways and then start thinking about changing panels to save a few kg's here and there.
32 gtst are light compared to 33 and 34's obv and i can guarantee there is plenty of 33/34's you could drive that would feel allot sharper and lighter but are actually a fair bit heavier than your car.
something to think about!
Cheers.
https://www.sau.com.au/forums/topic/176009-vehicular-diet/#findComment-3222580
Good point..
I got coilovers.. and front strut bar.. and rear sway bar..
But its not a GTS ot GTS-T.. Its a GTS4 AND a 4 Door..
..the price you pay for being unique..
I just may do a write up in the next comming weeks when I collect all the parts at once..
https://www.sau.com.au/forums/topic/176009-vehicular-diet/#findComment-3223299
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
