well, im still stuck a deleribating on what turbo setup todo. i've go everything eles ready motor preped and my s14 240sx chassis is just sitting there waiting but im stuck on what turbo setup to run!!this is what i know- im looking for nice power numbers in the 400hp, with a great powerband but want amazing or the best i can get RESPONSE that is the main goal a very nice boost curve, i know making hp numbers out of a rb26 in not hard to do but i want a very quick spooling setup with great response. so the first selection of turbo's is what my choices are to run for my twin turbo setup. i have a choice between the three posted below. the next choices are for a single turbo setup. im not really great understanding all this turbo stuff that why im asking the pro's like you guys on this fourm, i know there are lots of turbo's to choice from and rb26 setups aren't cheap by all means but these turbo's are all around the price range i can afford so if you can try to keep comments on whats posted but please if u need to infom me by all means teach me please i would love to learn and understand, thanks in advance pual f.
first turbo is a full t3 turbo 4 bolt rear exhaust housing
specs.42 cold a/r • .48 Hot • 2" OUTLET • • TURBINE WHEEL: EXDUCER: 1.81", MAYOR : 2.48" • COMPRESSOR WHEEL: EXDUCER: 1.67", MAYOR : 2.36"
second turbo is t3/t4specs:.50 A/R COLD
.63 3" SUPER VBAND OUTLET
a.. 3" INLET DIAMETER
b.. 2" OUTLET .57 COMPRESSOR WHEEL TRIM
.60 A/R COMPRESSOR
.63 A/R TURBINE
57 TRIM
third turbo is t3 super 45specs:STAGE III WHEEL
45 trim (21lb/min)
45 TRIM
2.36" INLET DIAMETER
2" OUTLET
WET FLOATING BEARINGS
1/8 NPT OIL INLET
T3 / T4 FOOTPRINT OK !!
FITS T3 AND T3/T4 MANIFOLDS
SPECS:
. 42 A/R COMPRESSOR
.48 A/R TURBINE
TURBINE WHEEL:
T04B
45 trim (21lb/min)
EXDUCER: 1.91"
MAYOR : 2.48"
COMPRESSOR WHEEL :
EXDUCER: 1.86"
MAYOR : 2.36"
sorry for the long post but this is what i found for my twin turbo options single turbo options
first turbo is T4 60-1specs:.60 COLD , .80 HOT , 3" EXHAUST OUTLET
second turbo is T4 GT66GT45 Full Tangential T4 Turbo .81 A/R V-Band Flange 4 inch exhaust outlet
third turbo is t4 turbo stage 5
SPECS:
a.. .60 - T COMPRESSOR WHEEL
b.. " STAGE V BRAND NEW " T04 " P "
1.05 A/R TURBINE HOUSING
a.. COMPRESSOR HOUSING A/R .60 TO4E
b.. INDUCER 2.324" / MAJOR 3.00"
this is all the info i could find on these turbo's but like above stated im looking for the setup with turbo choice with great power but the best throttle response and great boost curve i know u cant have it all but throttle response is #1 to all
thanks!!!
Edited by paul f
2530's are too big for 400hp, and do not have the same spool characteristics of the stock turbos
GT-SS's are perfect for 400hp, and have very similar spool characteristics to that of the stock items.
All the other turbos there you've listed, IMO, are not going to be as good as something designed specifically for the RB26.
So they are all going to be a compromise
What is your budget anyway? First of all you asked for the best setup, now your saying you are restricted :D
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
