Hey guys. My GTR has done 130'000 kms and now that i have a small cold idle problem i thought its time to clean the injectors anyway so i can be confident they are ok before i start changing anything else.
I read peoples posts here about aftermarket injectors but i think the Standard ones will satisfy my future needs. As long as they will be as good as new once serviced.
Ive got some questions...
Would a 89 GTR have top feed or side feed injectors ?
Is $180 ok price to clean/test injectors? (i will be supplying them the fuel rail with inj)
Which way is easier to get the fuel rail out. Remove the plenum or leave it on ?
Do i need to buy some o-rings or something when putting injectors back in ?
I read here inlet manifold gasket is $85. this is ridiculous if its true. Might just use loctite 515
A GTR would have top feed injectors.
To clean and test flow your injectors, it's about $40 per injector. Six injectors make it about $240. I would say that $180 is a good price to get them cleaned and tested.
And it's a good idea to get new o-rings when you put your injectors back in. Some have got cheap o-rings from supercheap auto and they've leaked. They recommended genuine Nissan items.
I'm not too sure about your others questions mate.
leave the plenum on
just remove the two bolts that hold the fuel rail in
you also have to remove the breather hose that gets in the way and all associated vacuum and fuel hoses (obviously)
Removal and install is too easy.
Common practice is to get them flowed, then place the highest flowing ones in at the rear to combat the unequal plenum flow. Agree with ^^ above, OEM rings and insulators as AM ones have leaked on me before. Little pit of petroleum based lube on install to keep them supple.
Cheapest inst always best. I have heard / seen some dodgey operations, with home made inj pulsing units and apprentice mishandling. Also please keep in mind they 18yrs old and new direct fitments SARDs are like $110 each
Ta
$580 delivered from nengun for Sards thats extremely cheap.
Sard also have a lot of their range in twin sprays now. Of which I've seen a set of 800cc twinspray sards work extremely well at idle/low rpm; excellent atomization and great fuel economy. I was a little skeptical from the old sard single spray squirters. :thumbsup:
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
    • Damn you’ve done well, definitely snapping necks.
    • Great weekend and event. Open fire at the caravan park, perfect weather all day and a great feed and a couple of drinks at at awesome country pub.
