Hello
I have a R-32 GTS-t and I have 102000 km on it. I have to change the timing belt. I was wondering if it is a good idea to do a engine rebuild? It works fine but I want to extend the life of the engine. Plus I want to put aftermarket cams in there. I have a engine manual and know some mechanics who are good at rebuilding engines(They havent worked on the RB engine but have done other American and Japanese engines) They are willing to help me. I have never taken apart or put a engine back together but I am mechanically inclined, I like and I am good at taking apart things and rebuilding them.
Is this a project I should undertake or should I not do it?
Help
https://www.sau.com.au/forums/topic/176050-rebuilding-engine/
I'm no pro but I would wait until the engine needs a rebuild. No point rebuilding it with all factory components if you're going to do some serious mods to the engine. If you have those mechanics at your disposal, I'd just mod it and drive it until something breaks, then rebuild it with stronger internals and all the things you'll need for it to cope with the power you want to put through it.
deff change the timing belt and if u want go as far as changing all the oil seals aswell do it.. if it drives fine, just keep driving it... if anything blows either rebuild or upgrade but until then save and save and save for when it finally happens.
Liam
Check or replace the water pump and idler and tensioner bearings also, for peace of mind.
cheers
Yeah I wouldnt worry about rebuilding it if you have no reason to - ie if you dont plan on making big power or the engine isnt showing signs of needing a rebuild.
As people have said, do some solid maintenance on it (timing belt, water pump, idler/tensioner, and a good overall service at the same time, oil, plugs, coolant etc), and it should last for a while yet :rant:
Definetly change the water pump!! as ive just figured out if it begins to fail then you need to remove timing belt and all that. saves you on labour costs. now just waiting for the parts so I can get it all done. dirty water pumps should of made replacing them easier!!!!!!!
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
    • And....if that could be true for all R34 GTTs, then it might be good. But in reality it is not really any better than my standard instruction to "go out and have a look at it yourself, and wave a tape measure around" etc etc, because as soon as you have any adjustable arms, or coilovers with smaller diameter springs, or tyres that have any bulge that goes out further than the rim, etc etc, then the simple version of the information is still potentially misleading. Plus, nothing in this is static. Everything is moving. At the rear the wheels swing inward at the top as they go up, so the clearances on the inside change as the suspension is compressed. At the front it's even worse. And then you have the difference in absolute wheel position in the arch can move around more, or less, depending on how compliant the bushes are. If, like me, you have sphericals on the front caster rods (and on the FUCAs also, but these are probably less dominant when it comes to wheel position), then your wheel will swing forward/backward under loads, as well as up/down, as well as steering angle. You end up having the simple numbers with 17 caveats/footnotes for each.
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
