Who knows about PAINT
Guest YZF-R1 Maniac
Hey guys. Im in the market for a R33 Skyline GTS-25T at the moment. Been looking in all the usual places and most of the good cars i can find are white. I realise that it is a major job to change the colour of a car(well to do it right anyway) Has anyone changed the colour of their car and if so what sort of price did it cost them?
Also how hard are the lower standard front bars to find if i got a car without one on it already.
Cheers:burnout:
https://www.sau.com.au/forums/topic/17606-who-knows-about-paint/
i dont know about tassie but here in syd u wont get a change colour job for less than 5k
and i assume that u are talking about the m spec lower front bar cos there should be a few around the wreckers, might have a few scratches or not the right colour but there gonna cost u about $4-$500
if the factory option bar (you refer to as M-spec) is up to 500 bucks, cant you get a GTR copy for 550? looks way better, but i suppose then its another 150 for indicators... But still, is better in the end if ur getting FMIC as the mouth on GTR bar is much better for intercooler airflow. (I say that but im running FMIC with the non-factory option, most restrictive front bar you can get :cheers:)
Yeah if you are going to do a full respray then I'd get a GTR copy bar. Personally I think you'd save more money by finding a car the right colour in the first place. Finding a coloured one with similar condition/mods than a white one may cost a little more but not $5k more. It's often less.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
