1) Pop cap off the end of the arm
2) Unbolt nut (14mm?)
3) Pull and wiggle.
Hehe! It's that easy man. Same as any other car really. The cap is the round "dome" like thing, which will have a little marking around the outside of it where you can pop a small flat-head screwdriver. A little twist of the screwdriver, and the cap will lever off.
Pay attention as to where the wiper blades sit on the windscreen, so that when you put them back on, they line up. If you miss this, it's just trial and error lining the wiper up with the spline when you put it back on.
Step 4... gloss black spraypaint from AutoOne ;o)
Ummm... you can take the blade off the arm too. It's a clip that depresses, and then you slide the blade part downwards and it slides off the arm.
https://www.sau.com.au/forums/topic/176089-r33-wipers/#findComment-3224774
    • Just buy a BMW if you want that... You can then choose whatever engine of theirs you want 😛
    • Clear vinyl wrap or clear coat?
    • There really needs to be an ODBII item that can play intake noise through speakers, synchronized with your current RPM and TPS%.
    • Worth most of the $50k alone!
    • So, we now have a straight and clean boot lid inbound and the car goes in for paint, again, on Wednesday, and will be ready on Friday, all ready to get cams and stuff on Monday  And by straight and clean.....I mean a brand new OEM one that cost..... $1300....😪 Sadly there's no clean undamaged used soft top version available, plenty for the power retractable hard top versions though, which is arse and makes Mark have the sads I could have waited longer, until a NC sort top boot lid eventually turned up, but I'm sick of waiting and said fark it and made it rain cash, meh In other naturally aspirated news, one of the guys at work brought in his old Corola which had a 4AGE in it, really nice clean car with lots of mods, including ITB's, man that things induction noise sounds sick with all of the dorts that makes you smile......maybe the NC needs ITB's, yeah, basically for the noise they make, but they're pretty expensive, but, they sound so damn good I may bring this up when I drop the car up on Monday, and by may, I mean I will🤣🤑🤪🤣
