Hi there,
Yep i blew the gasket last weekend at Wakefield, and the quotes for the work are BS. So i was wondering is it possible to replace it without removing the turbo completely after all we are talking about a gasket thats less than 2 mm's thick! If you dont know please dont reply okay. cheers
Impossible.
Hence the pricing. Its a royal pain in the ass.
While your at it, you might aswell replace the manifold gasket (to the head) aswell. Its not a lot more work once the turbo is off
And should your car shit one of those in 6 months, you'll cry if you didnt get it done :D
Thanks Nismoid,
I hear ya about the 6 months down the road okay, but are you saying there absolutely no movement(impossible) of the turbo with the bolts out not even 2 mm's?
theres nuts that hold the turbo onto the manifold unless yours has been messed with. it would be better doing all the gaskets at once instead of one at a time when they blow
Thanks Turboedsloth and Nismoid,
I just had another look at it , i thought they were bolts and not studs with nuts my mistake yep impossible is the right answer I guess I was overly tired on Sunday after two late nights and working saturday before driving down........what a sucky situation if they were bolts it would be so easy. guess i'll have to pull it apart saturday and hopefully finish by sunday night for work on monday.
Adam,
i was knackered on sunday cant remember you telling me jack about it lol i'll need you to come over seeing you are on holidays j/k
im going to start on it saturday arvo.
yeah u can do that. you can even do it if its all standard you just have to watch you dont kink/overly bend the oil an water lines an bugger them up. thats the easy slack way of doing it. if it were me id pull the whole lot off an reseal it all
I thought it was possible especially if you have braided/flexible lines...remove the 4 nuts and pull the turbo out slightly to remove the gasket and replace it...is that correct?
well, that to me qualifies as "removing the turbo".
Your un-bolting the whole thing, so it counts in my book
Ok, there seems to be a few conflicting posts above. I'll clear things up. I'm not contradicting anyone, just repeating what everyone has said:
If you undo the nuts, you can lever the turbo off the manifold, put a new gasket in. This is not ideal, because it may kink the water/oil lines. The lines will be bent and then bent back if you do this. It may be ok. Personally, I don't do this.
The better option is to just unbolt all of the lines, and then pop the turbo off the manifold.
Just do it properly. It's only a couple extra steps (takes me about 10 minutes more)
PS: use a genuine nissan gasket. Those squishy goo sandwitch aftermarket gaskets will probably shit themselves in 6 months
Thank you all,
I have the genuine gasket Whore, and Adam of course i'll take of the inlet and exhaust pipes hey this isnt a job i want to do after every race meeting i can tell ya, cheers oh the joys of things breaking :)
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
