get copper plugs not platinum or iridiium.
waste of money.
copper plugs and split fire coil packs.
and you have an R32 GTR.
if it has the stock wheels, you have the best rims you can get already.. why change it?
LMAO at the compression check by first mechanic..
I was looking at your photo of the GTR and thinking
"what a great looking GTR and still with the original wheels which also look the goods!"
Dont change them and you will be unique! :domokun:
In SA dealers have a duty of care 3 month warranty if the car is over a certain price. Must be different in every state. That's why I went to a dealer, I know I paid too much but I did get some peace of mind. (Since found out how much my Advan wheels cost new, so don't feel so bad about the price :domokun: ) The 33 I bought was the cleanest, most unmolested one I had ever seen as well.
I thought about getting a GTR but I knew I wouldn't be able to fix one if it did blow. I read a thread on this site somewhere about engines blown up and they were almost all RB26's... the few RB25's that went were highly modified running very high boost (of course there are always a couple of unlucky people). As much as I wanted a GTR I realised I only needed a sports car, not a race car.
My 2c
So, $1400 later i've got my car back and it seems to be going alright. I'm pretty happy, it's running smoother than ever, and sounds good. Maybe all it needed was a good service in the first place? Had all my oils changed, NGK Platinum spark plugs, Splitfire coils, so shouldn't have any more issues there.
Now i just need to pay off the monsterous debt i've racked up with this car, and then it's time for some mode, woo!
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
