Hi guys,
I am wanting to know what is required to change if you upgrade the stock turbos to a direct bolt-on, such as the Garrett 2860r -7's?
I know you can get the genuine gaskets from Nissan, wondering what exactly i need, and where is the best place to source them from?
Anyone have any contacts??
Cheers!
Dan :D
https://www.sau.com.au/forums/topic/176213-r32-gtr-turbo-gaskets/
and manifold to head gaskets, also turbo inlet gasket and turbo outlet gasket, also washers for the oil feeds and water feeds and for the oil drains and water drains. there is a nissan gasket kit that has all that stuff in it.
hey BeerBaron do you mean the 'engine' gasket kit available through nissan-which has head gasket etc. as well? or have you found a supplier who does a 'turbo changeover' set, with only the required bits and pieces? my local nissan dealership spares guys say it has to be ordered seperately :)
hi mate. there is a nissan turbo gasket kit. I am not 100% sure which gaskets it includes but the nissan part number is 14401-24U26. It should cost around $150 or so. at worst it you may have to buy the manifold-head gasket seperately.
failing that HKS sell a kit too with all the gaskets but it's around $300 or more.
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
